Hi Folks,
When I'm putting the convertible top down or up, when I get back in the car, the horn sounds three times. The following are the steps I do.
1. Ignition switch off
2. MN6 in neutral
3. Turn convertible top latch, windows roll down
4. Exit the car, close the door
5. Store top
6. Re-enter the car, close the door, horn sounds three times
Does the car think I've left the fob in the car even if I've exited and closed the door with the key in my pocket?
Although the owner's manual doesn't mention the beep, it does say you should set the parking brake. You didn't include that in your list. If you're not doing it, try setting it and see if that eliminates the beep.
...Does the car think I've left the fob in the car even if I've exited and closed the door with the key in my pocket? ....
I think that is the case, try walking away and leaving the car alone for a couple of minutes before getting back into it, I think that'll stop the 3 little beeps.
I'm guessing that you stay within the range of the fob sensor in the driver door frame. I don't get the beep, but I don't close my door either. I know if I get out to fill my tank and close the door, I will get the 3 beeps sometimes when I get back in.
When I had my 05 Vert I put the top up & down many times, some times the brake was on sometimes not. Never had the beeps.
Hey you never know, when your dealing with electronics
