help -problems starting
Old Aug 19, 2007 | 08:12 AM
BrettC6's Avatar
BrettC6
Default help -problems starting
Hi all,
the engine light has come on in mine, and now occasionally the thing cranks over forever before it eventually starts.
i read in the book that if the engine light is on it is a problem with the emmisions system?
anyone know what could be wrong?
cheers.
Old Aug 19, 2007 | 08:26 AM
patpprice's Avatar
patpprice
Not much information here. Year? Mods? Generally I'd start with the Fuel cap though. If you have the onstar, push it and ask them why the lights on. They'll give you a general idea. Good luck
Old Aug 19, 2007 | 08:34 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
A little more detail about the car would be helpful.
Old Aug 19, 2007 | 08:35 AM
BrettC6's Avatar
BrettC6
Hi,
its a stock 05, no onstar im afraid, i'm in australia. i the light could be on from low oil so i tchanged it and reset the oil life gauge but that didnt fix it.
Old Aug 19, 2007 | 08:38 AM
BrettC6's Avatar
BrettC6
otherwise the car runs fine, absolutley no problems, im not even sure though if the hard starting ( cranking over 6 seconds without starting ) and the engine light are related or not.
Old Aug 19, 2007 | 08:45 AM
talon90's Avatar
talon90
NCM Ambassador
Brett,
Is this still the original battery? It may simply be time to replace it. How many miles on the car. How often do you drive it and for how long. Has the battery ever gone dead?
Old Aug 19, 2007 | 09:02 AM
BrettC6's Avatar
BrettC6
Originally Posted by talon90
Brett,
yep original battery, it has been flat before when it sat for a couple of weeks not used, however its fully charged now and the starter motor cranks over really quickly. the car has 15,000 miles. i'm pretty sure the battery is ok.
do you know if the engine light being constantly on could have any relevance?
Old Aug 19, 2007 | 09:07 AM
BrettC6's Avatar
BrettC6
oh and it gets driven about once a week. both problems started about a month ago for no apparent reason. the car was converted to right hand drive about 6 months ago after i owned it in CA for about a year and has been faultless until these two problems.
cheers.
Old Aug 19, 2007 | 09:22 AM
talon90's Avatar
talon90
NCM Ambassador
Yes, the check engine light could be relevant. Usually a CEL indicates an issue with the emissions system and could be an air leak which could contribute to hard starting. If you can get your hands on a code scanner and post back with what codes it comes up with I'm sure someone here could help you diagnose it. Otherwise, it may be time for a trip to the dealer.
Old Aug 19, 2007 | 09:43 AM
BrettC6's Avatar
BrettC6
thanks mate,
the local dealer here wont scan it because they are afraid to hook it up to their machine, we have a similar car here that uses the C6 engine ( HSV GTS ) but as its a corvette they are worried the computer may de a little different and it could screw up.
Ill have a dig around for an air leak...
Old Aug 19, 2007 | 09:44 AM
not08crmanymore's Avatar
not08crmanymore
emissions
crank sensor
02 sensor.
Old Aug 19, 2007 | 01:17 PM
havesleep's Avatar
havesleep
I do not think your car would have any effect on there computer?
To help -problems starting
