oil filter?
Old Aug 23, 2007 | 10:54 AM
  #41
User 020720's Avatar
User 020720
I don't know what all the ooh ahh hooplah whoopdee freakin doo hype about oil filters is these days but the owners manual for my 07 calls for an AC PF48 oil filter so that's what I stick with. There's my $.02 for the day.
Old Aug 23, 2007 | 11:12 AM
  #42
cadguymark's Avatar
cadguymark
Originally Posted by PappyTinker
Come on now!!! Do you really believe that just because three different filters are made by the same company and LOOK like they have the same construction that they will perform alike??? What is the size of the particles, in microns, that each filters out. That could be significantly different in each different filter and it will make a big difference in how long your engine will last.
Come on!!! do you really believe there is a difference that matters? considering the miles most of us drive whether we use Mobil 1 or Amsoil, AC or SuperTech, it likely doesn't matter as long as we change oil & filter once a year in the spring.
Perhaps twice, for those with extra time and money and don't know what to do with it.
Old Aug 23, 2007 | 11:48 AM
  #43
User 020720
I've had my oil changed twice now per the DIC and my car is only 8 months old.
If I have extra time and money laying around I'd sure like to find it.
Old Aug 23, 2007 | 11:49 AM
  #44
dtwalkerfl's Avatar
dtwalkerfl
Years ago, a friend had a Fram filter on his Harley that must have had a defective bypass and didn't flow anything. He didn't have an oil pressure guage or light and his motor siezed.
Old Aug 23, 2007 | 01:12 PM
  #45
bernrex's Avatar
bernrex
Originally Posted by lt1george
The ones made in Mexico are junk. The mexican made filters do not say Duraguard. Only the ones that have printed on the side AC Delco Detroit,Michigan and say Duraguard on the front are the good ones.
Good advice for us .... thanks
Old Aug 23, 2007 | 01:22 PM
  #46
KenC6's Avatar
KenC6
Originally Posted by redrokit8
I would think it wise to stay with the oem GM filter as long as you are under warranty. The difference in price for the peace of mind is a no brainer in my book.
Not worth the effort to use anuthing else.
Old Aug 24, 2007 | 03:09 AM
  #47
gota07's Avatar
gota07
Cruise-In VIII Veteran
Originally Posted by FortMorganAl
Looks like page 9-899 was just left in by mistake. Sometimes evern RTFM doesn't work.
Makes me wonder just how much I can trust the accuracy of this thing.
Thanks for setting me straight.
Old Aug 24, 2007 | 02:10 PM
  #48
Les-10's Avatar
Les-10
Bow-Tie Guy
Originally Posted by VET4LES
I'm sure someone will post the link to the article but Fram is about the worst oil filter made.
True, they sure ain't what they used to be back in the day.
Old Aug 24, 2007 | 02:24 PM
  #49
shopdog's Avatar
shopdog
In this case, yes. They're all made on the same assembly line, just private brand marked and boxed differently at the end of the line. Super Tech is a fine filter. No need to pay extra for a different label.
Old Sep 8, 2008 | 06:39 PM
  #50
SweetBlueZ51's Avatar
SweetBlueZ51
I was looking for a post just like this because I just got back from Wal-Mart and picked up one of these Super Tech oil filters and was wondering if I've made a grave mistake.
Old Sep 8, 2008 | 06:42 PM
  #51
Rocketmanwpb's Avatar
Rocketmanwpb
Originally Posted by calemasters
If an aftermarket oil filter causes an engine failure, you may be on your own. If the AC Delco filter causes an engine failure, you have the backing of GM.
I do not think GM will take care of you if your aftermarket filter lets you down.
I don't think GM will take care of you unless they change your oil.
Old Sep 8, 2008 | 06:55 PM
  #52
WHT's Avatar
WHT
Originally Posted by xs650
Super Tech and Mobil 1 as well as K&N are all made by Champion Labs. Quite a few AC filters have been made by Champion. The Super Tech and AC made by Champion appear nearly identical while the Mobol 1 and K&N are more solidly guilt and have synthetic filter media.
The AC UPF44 filters I have appear to be made by Champion Labs. They are a step up in quality from the basic AC filter.
As mentioned, Mobil 1 and SuperTech oil filters are both made by Champion Labs. SuperTech is a good filter but it has been changed recently - (i) some parts that were metal are now plastic or fiber and (ii) the filter material is no longer synthetic.
According to Champion Labs: "The Mobil 1 oil filter is manufactured using higher quality materials and specifications and it is in a class by itself".
EDIT: Called Champion Labs and this info came directly from them.
Old Sep 8, 2008 | 07:22 PM
  #53
LMB-C6's Avatar
LMB-C6
I know Fram filters get bashed a lot - but I see them on the shelves in every store I go in.
Now, if they were so bad, and engines were blowing up coast to coast, how long would Fram be in business?
That said, I use AC Delco in my GM vehicles because $2.50 more for a filter on a $50k car isn't worth arguing about.
Old Sep 8, 2008 | 07:32 PM
  #54
RnLi's Avatar
RnLi
Good logic.....
Oil filters are much like engine oil. ALL are good and do the job. SOME just do it BETTER. Determining if YOU need better and how much better, is the KEY.
Also most owners on here must be paying/observing an aweful high price for OEM Delco. I buy mine at the dealer for $4.83 plus tax. At that rate, hardly worth considering an aftermarket.
