08 Tps
Old Aug 22, 2007 | 10:08 PM
Donn Malwick's Avatar
Donn Malwick
Default 08 Tps
Does anyone know if 2008 tire pressure sensors are the same part # etc as the 2007 ones, my dealers doesn't have that info yet?
Old Aug 22, 2007 | 10:10 PM
SlowAzzVette's Avatar
SlowAzzVette
Call large dealers, GM sends the data to the local dealerships in mid August. They should all have it already.
Old Aug 22, 2007 | 11:23 PM
BEZ06's Avatar
BEZ06
Forum vendor Fred Beans says that all C6's (2005 thru 2008, including all Z06's) use the same sensor.
For all cars manufactured to North American market specs (U.S. & Canada), if you check the list of RPO's on the sticker in your glove compartment, you'll see "UJ9" in the list. That is the exact same TPMS that all C6's have been delivered with (except cars made for overseas markets have "UH3").
If you have a "UJ9" TPMS then your car will need the sensors with the GM Part# 25758220.
Bob
U.S./Canada spec cars have the "UJ9" TPMS. The sensors transmit to the TPMS on 315 mHz (GM Part# 25758220).
Overseas (at least Europe) spec cars have the "UH3" TPMS. They require sensors that transmit on 433 mHz.
To 08 Tps
