Plug Wires
Old Aug 31, 2007 | 11:31 PM
rocket1's Avatar
rocket1
Default Plug Wires
I have seen a lot of advertising for plug wires with all kinds of claims about performance enhancements. Is there any value to some of these claims?
Old Sep 1, 2007 | 03:21 AM
shopdog's Avatar
shopdog
No.
The stock wires should be good for at least 80,000 miles (EPA mandate). There is no benefit to installing new wires before then.
Old Sep 1, 2007 | 03:38 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Even though cost and weight are two of the high priorites the design team had for the Corvette, power and performance were at the top of the list. It would be hard for me to imagine that they would be willing to compromise on the material or wire gage used in the plug wires for the sake of weight or cost.
Old Sep 1, 2007 | 07:36 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Old Sep 1, 2007 | 08:17 AM
6Speeder's Avatar
6Speeder
If you are running the stock exhaust manifolds, keep the factory wires. They're good. If you switch to long tube headers you might have a clearance problem and burn a wire. If so, MSD's are also good and can be bent to provide clearance around the hot exhaust primary tubes.
On my old LS1 with headers two wires were too close. On my current LS7 one would have burned up within minutes.
Old Sep 2, 2007 | 10:39 PM
rocket1's Avatar
rocket1
Thanks! Pretty much what I expected but it never hurts to check with the experts.
Old Sep 2, 2007 | 10:44 PM
GotCorvette?'s Avatar
GotCorvette?
When some of your plug wires are three feet long, better wires can make a difference. Not a big deal for us.
To Plug Wires
