difference between 87 octane and higher
Old Sep 4, 2007 | 10:27 PM
cadguymark's Avatar
cadguymark
Originally Posted by kgelliott
While we're discussing dumb questions regarding octane...
Earlier, before the $3/gal. stuff, premium was always .20 mor per gallon than 87 octane regular. I've noticed that lately the spread in cost has increased. Is it actually costing more to refine premium grade gasoline than it used to? Why the spread to begin with?
I found a place that is only 10 cents a gallon more, plus all the Kwik Trips around here sell top tier premium for 14 cents a gallon more, look around, you may find it cheaper elsewhere
Old Sep 4, 2007 | 10:39 PM
goatts's Avatar
goatts
Originally Posted by robl45
actually, they say you can run 87, they say for the z06 that you shouldn't accelerate hard or anything as you should run minimum 91.
22 cents a gallon adds up when you drive 20K plus miles a year.
20 years ago when I was building my '69 454 I thought I would have to permanently retard the timing so it wouldn't knock using modern fuel (I also considered water injection) but it ran fine on high test. Problem with the C6 is that you may not hear any problems with the windows up and the AC on.
Also, you're saving less than 22 cents per gal since your miles per gal will drop due to the timing being off.
Old Sep 4, 2007 | 10:57 PM
robl45's Avatar
robl45
I wish it was like that around here, 22 cents is like the low end, I"ve seen some places that are 30 cents or more spread for premium.
Old Sep 4, 2007 | 11:56 PM
4thC4at60's Avatar
4thC4at60
AT 15 mpg that works out to a bit more than $300 a year.
Old Sep 5, 2007 | 12:03 AM
haljensen's Avatar
haljensen
Premium and Regular use the same base gas and different anti-knock additives, the cost of the additives is the additional charge.
Old Sep 5, 2007 | 01:13 AM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
An off shoot of this thread......I heard we can have our vettes programmed to run better if your using 92/93 exclusively? :
Old Sep 5, 2007 | 01:21 AM
cadguymark's Avatar
cadguymark
another option is to look around for midgrade, 89 octane, the place by me that sells premium for 10 cents more than regular sells midgrade for 3 cents more, a station diagonal from them only sells 89 octane for the same price as regular, they both are usually the cheapest places in town.
Old Sep 5, 2007 | 01:47 AM
FNGVetteFan's Avatar
FNGVetteFan
the sound of Mustangs, GTO's, ... passing you
LMAO, that angle took me by surprise. Too funny
Old Sep 5, 2007 | 02:19 AM
Vetteoholic's Avatar
Vetteoholic
Originally Posted by DJackman
Since you've been using 87 for a while, you probably will not hear the knocking/pinging. Your Knock sensors and ECU has already taken care of that. Your ECU should have already learned it by now and your car should already be running on the 87 timing map. You can always switch back to 91 or higher anytime you want, your ECU will figure it out.
But then again I remembered test driving a used 2002 Z06 and under full throttle the car detonated like crazy. We pulled over and I put about 5 gallons of 91 octane and instantly the knocking went away. A knocking is a loud Klick Klick Klick sound under a full throtle, some ears will hear it some wont. Me, I can hear it instantly while some of my friends would look at me weird and ask "what sound"?
On both of my Corvettes I've been using (Shell 93oct V-Power) I personally really like this gas. Most of the major name brand gas is good, alot of it is the same gas I believe. My car always seems to run good, not sure if it's the gas but whatever.
Old Sep 5, 2007 | 06:49 AM
robl45's Avatar
robl45
At least 10 cents difference here. I used to run 93 or 94 exclusively but switched to regular when prices shot up. Believe it or not, 300 dollars a year is a lot to some people. That goes towards my insurance or other daily living expenses. Thats how I manage to own this great car and hang out with you guys.
Old Sep 5, 2007 | 07:32 AM
NJAg78's Avatar
NJAg78
{[20000 miles/year]/[20 miles/gallon]} X $0.22/gallon = $220/year
$18.50/month for gas doesn't seem like a lot when you are driving a $45,000 + sports car.
Also seems a little strange that on the same board where we are worried about the difference between regular gasoline and "high octane" we have guys who intentionally go out and "melt down" tires that run $350/ea.
Old Sep 5, 2007 | 07:39 AM
NJAg78's Avatar
NJAg78
Sorry, but this is bad information. Gasoline octane is "blended" at the refinery to be and sold to whoesalers as 87, 89, 91, 93, etc. Refineries have units that convert lower octane belndstocks to higher octane blendstocks. This generally results in a volume shrinkage and partially explains the higher cost of increasing octane. Alkylation units (HF and Sulfuric) and Nahtha Reforming units are both examples of lower octane to higher octane conversion
Old Sep 5, 2007 | 07:51 AM
  #33
Haplo5's Avatar
Haplo5
(20k a year / aprox 20 miles to a gal) * $0.22 = $220.00 extra a year
The extra HP is worth $18.00 a month
Sorry did see the other post befor I replied
Old Sep 5, 2007 | 08:45 AM
  #34
FloydSummerOf68's Avatar
FloydSummerOf68
Is an extra 4 bucks going to kill you at the pump to use premium? You're driving a 50K dollar car, lol.
Edit-damn...should've finished reading the posts before I posted, lol.
Old Sep 5, 2007 | 08:49 AM
  #35
FloydSummerOf68
The higher the octane you run the more agressive of a tune you can have with better use of timing advance.
Old Sep 5, 2007 | 09:01 AM
  #36
robl45's Avatar
robl45
I used to melt down tires as well, but not when they are expensive like on this car. I have yet to spin the tires. Just not worth it. And 220 is still money. Actually its more in my case because 20000 miles or so is just driving to work. I still actually drive the car for pleasure as well. I got my car getting squirrly on me in the morning so I can assure you guys its not losing that much power running 87.
Besides, the question of this thread was what is the main difference between 87 and 93. I don't understand why these threads always have to turn into a war.
Old Sep 5, 2007 | 09:08 AM
  #37
FloydSummerOf68
Bottom line is this...if you're happy with regular, go ahead, but your car WILL run better, perform better, and get better milage with 93 over 87...the cleaning additives put into most premium gasses at high tiered stations will also help to keep your valves and injectors clean.
To difference between 87 octane and higher
Old Sep 5, 2007 | 09:28 AM
  #38
titletaker's Avatar
titletaker
I don't think people are trying to start an argument with you, I think they are pointing out a different way to look at things. If you really want to factor everything into the equation, maybe you should consider the resale value hit you face with 20k miles per year. It sounds like you enjoy driving your vette and if you want to put in 87, that is certainly up to you. Most vette owners are on the picky side, so they have a different mindset at the pump. I personally wouldn't ever consider putting anything less than 92 octane in my car, but I only put on about 3k miles per year and like the added power and that detergents included in higher octane premium fuels.
Old Sep 5, 2007 | 11:29 AM
  #39
Vetteoholic
The cost difference is so little, I have to laugh when people won't buy a car that takes 91 or better. At my gas station the difference between 87 & 93 oct is only .20 cents/gal. So If you have a big 20 gal tank thats a whopping $4.00! I don't know about you, but that seems like a great deal for better overall performance.
* Sorry, I just read the post's above. This was already metioned, but it's so true. If you drive a Vette, I don't think 4-5 bucks are gonna put you in the poor house, unless you live in your Vette lol
Old Sep 5, 2007 | 11:38 AM
  #40
dandlb's Avatar
dandlb
Hat's off to JJC5 and DJackman for great answers to this question! I think most people don't understand what octane means to gasoline. You 'splained it clearly and concisely.
