Tires - Need Quick Advice
Old Sep 7, 2007 | 01:49 PM
Wingrider's Avatar
Wingrider
Default Tires - Need Quick Advice
I have a standard 2006 A6 that needs tires. I want the new Firestones, but everything I see says they are for the Z51 only. Can I use them for my standard coupe? Thanks. (Any feedback from users also appreciated.)
Old Sep 7, 2007 | 01:56 PM
tluck's Avatar
tluck
Purchase decision should be based on how you drive the car. If you're looking for traction, BFG KDW2's will fit the bill. These tires are not run flats, so I purchased from Tire Rack a pump with a latex gel. The gel can be removed from the inner tire with just a water hose.
Old Sep 7, 2007 | 02:01 PM
carpe dm's Avatar
carpe dm
I had Firestone Firehawks on one of our C5s, and really liked them. Check out the Tire Rack for ideas. Out here in the wide open west, runflats are the no-brainer choice; you may be able to live without them in your local.
Old Sep 7, 2007 | 05:03 PM
Leverage's Avatar
Leverage
Default BFGs
My BFGs are great and look awesome from the back of the car.
Old Sep 7, 2007 | 05:34 PM
Sawbladz's Avatar
Sawbladz
Just changed from BFG G-Force KD's to Firestone Wide Ovals. Kinda disappointed. The new tires have a very narrow section/tread width compared to the BFG's. They almost look stretched on the rim. The also don't have as much traction as the KD's did. If I did it again, I would get another set of KD's.
Old Sep 7, 2007 | 06:09 PM
blkc6z51's Avatar
blkc6z51
Yes you can use the Firestones on a standard vette. the Z51 guys
use them to save $$$$ and get better miles out of the tires.
Go for it.
Old Sep 7, 2007 | 06:23 PM
beefsvet's Avatar
beefsvet
Default tires
How many miles do you have on them Mine have 14,500, and they are wearing un even Beef
Old Sep 7, 2007 | 06:36 PM
Firedog's Avatar
Firedog
The Z51 tires are the same size as yours, just a little stickier; and consequentally, will wear out sooner. If you want 'em, get 'em...
Old Sep 7, 2007 | 08:16 PM
shopdog's Avatar
shopdog
I just put another set of Goodyear GS2 EMTs on my car. The first set lasted 42,000 miles, and would have gone further if I hadn't had an alignment problem which caused one of the fronts to wear excessively (hit a hole and the first alignment shop didn't put it back right). I looked at the Firestones, but I actually got a better deal on the Goodyears thanks to Tire Rack's special.
I've been relatively pleased with the GS2s. They wore well, and they endured 3 flats with no adverse consequences. Better wet and cold traction than the SCs too. The Firestones still have a lower tread life rating than the GS2s. I considered them because people said they rode better and were quieter. But frankly, the GS2s ride well enough, and they didn't start to get really noisy until near the end of their life (and I think that was mostly due to the uneven wear from the bad alignment).
If I didn't take frequent long trips, sometimes to very remote areas, I'd have considered a non-runflat. I've always liked Michelins. But with no provision for a spare in this car, I'm sticking with runflats.
Old Sep 7, 2007 | 09:49 PM
Wingrider's Avatar
Wingrider
I have 28,000 miles on the tires. However, this includes some track work, both road course and strips. So I guess the miles are really not too bad. It looks like I will try the Firestones. Thanks for the thoughts.
Old Sep 15, 2007 | 04:12 PM
john_uk's Avatar
john_uk
So let me get this straight, it IS possible to put none runflats on my C6? Corvettes are very rare here in the UK, so most tyre shops can't give me good advice.
I currently need new tyres all round. Goodyear run flats will take a good month to get here on order??! But I can get none runflats next day.
John
Old Sep 15, 2007 | 07:40 PM
rsilverman's Avatar
rsilverman
Default I bought the Firestones - Happy
I have about 20K on the Firestone Wide Ovals.
Quieter, smoother, and good traction (Dry and wet)
I will buy them again.
56k on my 06 C6, Auto, F55.
Old Sep 15, 2007 | 08:28 PM
john_uk's Avatar
john_uk
So you don’t notice any difference in handling etc, like some of the others have noticed here? Did you have to chance the valve sensors too?
Old Sep 15, 2007 | 08:39 PM
Fast stuff's Avatar
Fast stuff
Default Tires
Just put the firestone wide oval run flats on my C6 and I LOVEM $1200 installed with road hazard
Old Sep 16, 2007 | 10:26 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
It looks as if you got 36k on your OEM's .Is that possible?
Old Sep 16, 2007 | 11:02 PM
rhoward2's Avatar
rhoward2
Old Sep 17, 2007 | 04:05 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
For Z51 only is
Your wheels and tires are the same size. I have FS and l;ove them. BFG KDW2 is another great choice.
To Tires - Need Quick Advice
