Lifting C06
Old Sep 7, 2007 | 04:03 PM
choivette's Avatar
choivette
Default Lifting C06
Wanted to pull tires off one by one to clean rotors and brake dust as well as putting fender guards on while tire was off. Read manual and saw two point lift locations. Can anyone give me some ideas and what to use to lift car.
Thank you
Old Sep 7, 2007 | 04:16 PM
C6FirstVette's Avatar
C6FirstVette
Just use the outer perimeter rail sites... with a puck or a small block of wood so as to not damage the body panel in the area of the perimeter rail lift site
Michael
Old Sep 7, 2007 | 04:23 PM
Zymurgy's Avatar
Zymurgy
Moderator
You can lift at the black locations, use something to protect rocker panels.
Old Sep 7, 2007 | 05:29 PM
choivette's Avatar
choivette
pardon me in advance. If one was to use the red points. is it a two point lift? Also I assume the perimemter is a single point lift. I have lift pucks.
Thanks for patience.
Old Sep 7, 2007 | 05:53 PM
stlthxlr8r's Avatar
stlthxlr8r
I believe you can lift separately on each of the 4 red dots (ie do one wheel at a time) - somebody here confirm?
Old Sep 7, 2007 | 05:57 PM
Beezvette's Avatar
Beezvette
If you search the forum you will find the solution, it has been discussed many times. There is a unit you can buy that fits a low profile jack that lifts both points from the back or front. I made one out of wood and it works fine. I drive the front onto ramps (also wood, that I made), jack the back and put blocks under the back tires. The back needs to be an inch or so higher to allow the oil to drain if you're changing the oil.
Old Sep 7, 2007 | 05:58 PM
C6FirstVette
For what you are doing the perimeter rail sites are just fine
Michael
Old Sep 7, 2007 | 06:33 PM
choivette's Avatar
choivette
thanks, forum has been more of help than my local chevy dealer.
To Lifting C06
