ls2 edit question
Old Sep 8, 2007 | 06:50 PM
VETTAMOUS's Avatar
VETTAMOUS
St. Jude Donor '11-'12, '14
Default ls2 edit question
i bought mine used , previous owner stated it had a ls2 edit on it, does that edit change or eliminate the rev limiter?
Old Sep 8, 2007 | 07:21 PM
shopdog's Avatar
shopdog
The ls2edit firmware editing program is used by the tuner to change a number of engine parameters. One of those is the setting of the rev limiter. Whether the rev limit was actually changed when the edit was performed would be up to the tuner doing the work. In other words, the editor is a tool used by the tuner, like a screwdriver would have been used on an older non-computer car. It allows him to make changes to many of the factory settings, if he chooses to do so. It isn't likely one of those changes would have been to raise the rev limit, unless valve train work had been done to the car to allow the engine to safely rev higher.
Old Sep 8, 2007 | 07:53 PM
VETTAMOUS's Avatar
VETTAMOUS
thanks for info, i believe i have recieved some good info from some of your posts before. thanks again
Old Sep 9, 2007 | 08:14 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Shopdog's the man !!!!
To ls2 edit question
