Runflats
Old Sep 13, 2007 | 01:31 AM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
Default Runflats
i got a flat today and the tire shop says no fixy buy new tire. is this right? the tires (supercars) have 5800 mile on them should i buy just 1 or should i buy 2 of the firestones? does any one have any input on the wide ovals?
Old Sep 13, 2007 | 02:07 AM
American Made's Avatar
American Made
Double Naught Spy School
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Just interested, do you know what caused the flat? Im always trying to compare the stock wheels w/ run flats I have kept v.s. the bfg kdw(non runflat) I have on my car with diff. wheels. I would do either of what you suggested. If you havent been burning out buy one. If the tread is worn buy the firestones.
Old Sep 13, 2007 | 02:14 AM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
the cause is/was a big hole. i did get a tire shop to plug it to get me home but i will replace it. i have done a few smokies so maybe the ovals. does any one have any thing to say about the wide ovals?
Old Sep 13, 2007 | 03:10 AM
adias's Avatar
adias
If you switch 1 tire to a different type you MUST switch all 4 tires to the same brand and type. This is a high performance sports car and you should not risk it. You've got to pay to play.
Old Sep 13, 2007 | 09:44 AM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
so you can't run goodyears on the front and firestones in the rear? what difference will it make?
Old Sep 13, 2007 | 09:56 AM
SpdWhite's Avatar
SpdWhite
Find your warantee. I had a flat, nail through the sidewall. Goodyear replaced for $0.00. Time and mileage may vary.
Old Sep 13, 2007 | 10:00 AM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
OOOO warranty
thank you
Old Sep 13, 2007 | 10:03 AM
Landru's Avatar
Landru
Only 5,800 miles on a '07?
Goodyear's Tire Warranty will cover most if not all the cost of a brand new tire.
Old Sep 13, 2007 | 10:23 AM
Wingrider's Avatar
Wingrider
What he said. They should fix/replace for free.
Old Sep 13, 2007 | 10:40 AM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
thanz guys i will let you know how it goes
Old Sep 13, 2007 | 12:37 PM
Landru's Avatar
Landru
Whoaaaaaa there, partner.
Go to your owner's manual, inside you'll find Goodyear's seperate warranty sheet. Be SURE to take it with you to the Goodyear dealer or they probably won't know WTH you're talking about, OK?
Good luck.
Methinks you've a *new* tire coming at no cost to you.
To Runflats
