Window Valet Help Please
Old Sep 16, 2007 | 05:25 PM
Poppy's Vette's Avatar
Poppy's Vette
Default Window Valet Help Please
I just received my Window Valet for my 07 C6 (Model WV-110 in case it matters). Instructions say Window Valet for C6, so I think it's the correct model.
Anyway, I plug it in and nothing happens. As a matter of fact I'm glad I left my windows down to start because once I got out of the car I couldn't unlock it with the remote and the door wouldn't open so I had to reach in and unplug the module. I tried pushing the lock button 3 times, as the instructions said, to raise the windows but nothing happens.
Any advice?
TIA
Paul
Old Sep 16, 2007 | 05:34 PM
Grzldvt's Avatar
Grzldvt
Make sure it is seated correctly, some 07's had a film on the ADSL connector that causes connection problems
Old Sep 16, 2007 | 05:37 PM
Poppy's Vette
I tried pulling it and reseating it a couple times but are there other ways to verify it's seated properly? I know it is doing somthing because once it's in, I can't unlock the doors.
Old Sep 16, 2007 | 06:21 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
I don't know the answer to you question but I can say that the window valet for the C6 is flakey. I had the window valet for my C5 and it worked flawlessly. The one I have for the C6 does weird things. For example, if I try to use the "vent window" function, it never works and I have to reindex my windows. I'm probably going to just sell mine. It's too bad about the window valet for the C6 after having such a good experience with the C5 version.
Old Sep 16, 2007 | 06:37 PM
Poppy's Vette
Well that's a bummer. I hate to hear that. I bought it only for the window up and down function. I couldn't figure out how I was going to manage getting it up on my trailer and then getting out. I figured I would be able to drive it up, leave windows down, crack the door open and, with the window down, squeeze out, then close the windows and lock it. No way I want to climb out through the hatch. I'm way too old for that
Old Sep 16, 2007 | 08:10 PM
gbgary's Avatar
gbgary
mine works fine....has since the moment i installed it (car built 4-30-07).
Old Sep 16, 2007 | 09:52 PM
Grzldvt's Avatar
Grzldvt
Same here, mine has been flawless for 3 years. I would contact Top Down instead of guessing...
Top Down Tech
Old Sep 16, 2007 | 11:29 PM
User 020720's Avatar
User 020720
I've heard the later 07's have had issues with the obdii connector and the window valet but that reseating it a few times takes care of it.
My window valet works flawlessly in my 07 (built 11/06). I would hate not having the functionality it provides.
Old Sep 17, 2007 | 01:08 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Any advice?
TIA
Paul
PM sent.
Old Sep 17, 2007 | 07:14 AM
McClendons's Avatar
McClendons
I could not get the film off so that it worked relaibly. Could get it to work fine for a few days, then had to "break in" with the key. I am working the the company for solutions--he is very helpful. Have heard there is a new one with slightly larger prongs.
To Window Valet Help Please
