Hydraulic jacks, long reach, low profile: Omega 29023 and AC DK13HLQ
#41
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Sorry, Northern tool stopped carrying it several years ago. Here is the one from Summit Racing: http://www.summitracing.com/parts/SUM-918008/
BJK
BJK
#42
This one will because it has a 1" center pin, but you will probably want to cut it down so that you can get a minimum length of 22" which is what is required for the preferred lift points in the front of the vette.: http://www.summitracing.com/parts/SUM-918008/
Here is what I did to the one I got from Northern Tools a couple of years ago. : http://forums.corvetteforum.com/1576374804-post14.html
BJK
BJK
#43
BJK
BJK
#44
The Omega very well may have a bit more resistance than a lot of other common jacks. I will note that it did not have more resistance than the AC jack. Im thinking that long-reach jacks by nature may simply have a bit more resistance than jacks with less reach... its a leverage issue. Cant get something for nothing.
Could be. Its definitely not a one hand operation but I don't find it to be hard to use. Takes a little more effort though to lift my Silverado. Overall, I like it a lot.
#45
BJK
BJK
http://forums.corvetteforum.com/c6-c...ml?forum_id=74
#46
BJK
#47
I understand where you are coming from, and for many that would work great, but for me, removing the arms and putting the pads on top of the main piece will not lift the car high enough to use the Race Ramp 12" wheel cribs while leaving the wheels on and I hate using drive up ramps for several reasons. The main reason for using a cross beam adapter is to gain another 8 inches or so of lift. If that is not important, then just use a 2x4 on top of the floor jack lift pad. For me, I want to raise my car way up without opening the garage door and jockeying the cars and ramps around and then worrying about getting to the top without a spotter.
BJK
BJK
Ok - I see - how about some photo's in action. Are ramps a pain ? or unsafe ? what is the dn side - apparnetly you dont like ramps.
bandit
#48
St. Jude Donor '12
When I was searching for a low approach jack I had found the AC to be unacceptable in price. The reason was it is manufactured in Europe and the dollar being so weak vs the Euro made it cost 50% more....is this still the case?
I searched for the Omega and could not find one in my area.....another issue is these jacks are heavy so cost a bunch to ship them....
#49
If your interested, it's currently on sale for $247 w/free shipping.
- Minimum height of 1-1/3-inches
- Maximum height of 20-inches
- 41-1/4-inches in length, weighs-in at a little over 100 lbs.
#51
St. Jude Donor '12
I took BJK's advice and bought the ATD-7325 extra low profile tuner jack. Spent some time doing some comparisons yesterday. Bottom line; seems to be a very well made, durable, safe, extra low profile jack that should satisfy my needs just fine.
#52
http://www.amazon.com/s/ref=nb_sb_no...Jack&x=19&y=21
BJK
#53
#54
St. Jude Donor '12
There was another thread that provided a link to a Denmark site and the price for the AC jack was an astounding $800ish. When I got my Jack through Amazon it was $237 with free shipping. It is now $247
BJK
BJK
I was worried that the other jack had seal problems with it's hydrallic's. I had read that after approx year it would start leaking making it unacceptable in terms of saftey. I'm trying to search my computer to find where I put the info I found. Thanks for response. I'll post those reviews if I can find where I saved them. Tim
#55
I now use the 4" rollup ramps to give me more room for the jack if I have the adapter on it. I then lift the car in stages using a combination of jack stand, rollup ramps and either 8" or 12" wheel cribs, depending on what my needs are. I like the wheel cribs because you don't have to worry about the car rolling. I also like the fact that I never have to open the garage door. This keeps looky-loos at bay as well as the the sometimes extreme temps out of my heavily insulated and air conditioned/heated garage. It was 26* last night and 28* the night before.
I these pictures the preferred lift points are 24" from the floor and the bottom of the nose of the car is 30" up and I'm still not at full lift for the jack. I should also mention that I have the rear wheels on 8" Race Ramp wheel cribs.
BJK
#57
one issue that I have with the ATD Jack from Amazon is that the wheels simply do not roll very good at all. They seem to get stuck with even the smallest particle of dirt under them.
Has anyone replace those with something better ? Is there any way to improve them ?
#58
Northern Tool sells the Omega 29023 with a Blackhawk label for $279.99 + freight. It's made by ShinnFu North America and is identical to the Omega. It's the perfect floor jack for a C6 owner. Its only downside is its 125 lb weight, which added $75 to the cost for shipping.
