How to remove rear spoiler? I had a carbon fiber ZO6 spoiler installed on my C6 coupe and i am going to be selling it and getting a Zo6 so i would like to put the CF spoiler on the zo6. So if anyone has an easy way to remove it and put back the stock one please let me know.
ADAM
BTW, the nuts are 10mm - if you have to swap out the CMTL, which is held in place by the inner two studs, you will need a torx socket (not sure of the size). this is one set of tools (torx sockets) that i don't have in my garage. as a work around, i just used two 10mm nuts jammed together and backed the studs out to remove the lamp assembly. hope this helps...
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
ADAM
