LS3 Shortblock
Anyone have an idea of what kind of power the new LS3 motor can handle? Is is a forged piston? Just curious... Going to be selling my 8 second mustang racecar soon, and it will be replaced by an 08 AO Z51 6speed!
http://s52.photobucket.com/albums/g3...t=Numidia3.flv
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Having had a supercharged 302 I though you might be interested in this quote from the fall 07 issue of Corvette Quarterly
"In addition to larger bores, there's a small but significant machining change in the lower portion of the block to allow it to reliably sustain the higher loads associated with elevated cylinder pressure and the added output ........ " Yesssssssssssss
forged pistons are noisy on cold start up and GM got all kind of hell from customers about piston noise when cold on the first LS series engines and they were not even forged. the people buying corvettes now are not from the old school of clunking forged pistons used back in the 60s
Even with forged internals a stock block (302) was not strong enough to withstand much more than 500 HP for any prolonged period of time.
GM has insured that the LS3 block will be able to take more horsepower. If you add forged internals you can make a beast which will last.
