JSB color match
Old Sep 22, 2007 | 09:23 PM
2bubbas's Avatar
2bubbas
Default JSB color match
In different lights the car totally changes color. Today in full sun- the front fascia was not even close to a color match to the rest of the paint. Then 15 minutes later from a different angle it looked closer. I think maybe materials makes the difference. It will be something I'll live with. Is this why CR has been on constraint. Maybe they will be looking at JSB next.
Old Sep 22, 2007 | 09:29 PM
mpuzach's Avatar
mpuzach
What you're describing isn't unique to JSB or CRM; it can happen with any C6 color. The panels for a given car are not all painted together plus, as you suggested, they're not all made of the same material. There are bound to be slight differences between panels.
Old Sep 22, 2007 | 09:42 PM
tjl5709's Avatar
tjl5709
When I was at the plant last week, it was the first time I had seen JSB.
Of all the colors right now, it has the most color travel when you look at it from different angles. And that is what you are seeing. The front and rear fascias transition into the body panels at a little different angle, and it shows up as a color difference.
Old Sep 22, 2007 | 09:52 PM
Jet Stream's Avatar
Jet Stream
My JSB solid roof panel is a slightly different shade than the rest of the car. The top is a bit more blue in hue.
Old Sep 23, 2007 | 11:12 AM
HOTSOSS's Avatar
HOTSOSS
I observed a JSB coupe in the dealers showroom and the mirrows looked like a totally different color. Just the way the overhead lights hit I guess.
To JSB color match
