Another battery question???????????
Old Sep 24, 2007 | 02:03 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
Default Another battery question???????????
I keep having to jump my 05. The battery is draining between 5 and ten minutes. After I jump it my guage and dic read the voltage between 13.6V and 14.2V. All the lights work as well as the radio, it just won't start without a jump.
I haven't changed anything to my stereo lately. The only thing that i have done is change the consol to CF, but that was a week ago.
Should I just buy a new battery and what kind should I get? What is the difference between Optima redt op or yellow?
Thanks!!
Old Sep 24, 2007 | 02:05 PM
MNVette's Avatar
MNVette
As for the Optima, yellow tops are "deep cycling," meaning that they can withstand more total discharges than a regular battery (like a red top). I recommend the D35 Yellow Top for 2006+ cars (2005's use a different post system).
As for the cause, have you had the car reflashed? Any other electrical issues? Have you checked? If not, that needs to be done as well. Obviously, your battery is junk, but if the underlying problem isn't fixed as well, you'll just kill another battery.
Old Sep 24, 2007 | 02:08 PM
not08crmanymore's Avatar
not08crmanymore
Get a battery tender,hook it up,let it charge and see what happens.
Old Sep 24, 2007 | 02:12 PM
0SicMSP - Daniel
Former Vendor
Thanks guys!
Anybody know of the model number for the Optima battery for the 05 vettes?
Old Sep 24, 2007 | 02:41 PM
Modshack's Avatar
Modshack
No point to that. His battery is toast. Lots of failures here in 2 years or less.
Old Sep 24, 2007 | 02:47 PM
jonesaut's Avatar
jonesaut
Had similar problem with my 05 Coupe
Replaced battery with red top
Stock battery was only 12 months old
No electrical problems since
Old Sep 24, 2007 | 03:01 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by dpenate
Thanks guys!
For your 2005, I would recommend the Optima Yellow Top model D34 or D34/78. The specs are identical, only difference is the D34 has top posts only and the D34/78 has both top posts and side terminals. You can get more info at this website:
http://www.1st-optima-batteries.com/
Old Sep 24, 2007 | 03:07 PM
07MontRedcp's Avatar
07MontRedcp
Mine failed at 13 months. On or more cells had failed/shorted. Even on a charger for 2 days it would just turn over. Would go for a drive come back and it would be dead as soon as I shut down. AC DELCO batteries have had a lot of troubles for some time . Guys on the C5 forum have been reporting problems with the Optima also.
BJK
Old Sep 24, 2007 | 03:19 PM
0SicMSP - Daniel
Former Vendor
Thanks again guys!!
my battery is toast. only 10V when not turned on and 14.37 when on and everything inside on too. Must be a dead cell.
Here comes the optima
Old Sep 24, 2007 | 03:50 PM
07MontRedcp
Thanks again guys!!
And there goes $160. I choose to go to Wal-Mart. $52 and includes 7 year warranty with 2 Year free replacement.
BJK
To Another battery question???????????
