UPF filters???
Old Sep 27, 2007 | 04:27 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
Default UPF filters???
On my old SS, i would used the UPF44 filters. I just picked up my C6, and was looking for UPF48 filters, but the dealership says he has no idea of what a UPF filter was. I then tried google, and didn't anything either?
so, does anyone know where to get them?
Old Sep 27, 2007 | 05:27 PM
zare191's Avatar
zare191
I don't know what a UPF48 filter is, but mine uses a PF48 (Delco) bought at the dealer.
Old Sep 27, 2007 | 05:30 PM
Jimmy 2 Times
i know what a PF48 is.
THe Upf series of Delco filters have better synthetic filtering material on the inside, which offers better filtering.
Old Sep 27, 2007 | 05:31 PM
carpe dm's Avatar
carpe dm
I have used and still have a good supply of the UPF filters for our C5. I don't think they make a UPF filter for the newer C6s.
Old Sep 27, 2007 | 05:34 PM
Zymurgy's Avatar
Zymurgy
Moderator
According to "the other Corvette Forum", AC Delco no longer makes UPFXX filters (and never made a UPF48). AC Delco filters are now made by Champion in Mexico and branded AC Delco.
Old Sep 27, 2007 | 05:41 PM
Jimmy 2 Times
which I am not a big fan of, but because of warranty, I will have to continue to use the inferior mexican filters
Old Sep 27, 2007 | 05:57 PM
Miaugi's Avatar
Miaugi
I was using the UPF filter but will likely switch to Amsoil brand.
Old Sep 27, 2007 | 06:02 PM
blkc6z51's Avatar
blkc6z51
You can use any oil filter you want, warranty is still good.
Old Sep 27, 2007 | 06:09 PM
B-Myster's Avatar
B-Myster
Another alternative filter you could use is the Mobil One. I just called their hotline (800-882-0890) to find out the model number and was told it was the M1-113 for the LS3.
Old Sep 27, 2007 | 06:11 PM
Jimmy 2 Times
then what happens if my, oil pump takes a dump. They will likely state that the oil filter was not up to par, and will deny the claim. Then I have to tear the car apart to replace the pump.....and beings that I don't have a lift, i iwll do it on my back. just an example. I am familair with the moss-magnson act, but I am sure that somehow they will try to blame that if i need warranty service
Jimmy 2 Times
where did you find it?
Old Sep 27, 2007 | 06:52 PM
turmat's Avatar
turmat
UPF filters can only be used on C6's up until 2006. After that you are SOL. You can still get them from Ken Fitchtner and I think Gene sells them also.
http://temp.corvetteforum.net/c5/ken...rtspage8.shtml
Good luck.
Old Sep 27, 2007 | 08:22 PM
6 speed Sid's Avatar
6 speed Sid
I have used Mobile-1 filters in the last 4 Vettes and never a problem.
Old Sep 27, 2007 | 08:41 PM
lt1george's Avatar
lt1george
Default ac delco filters.
Never came in the UPF 48 size. Buy yourself a couple cases of PF48 from Gene.
Not all AC Delco Filter are made in Mexico yet. Make sure the box says(made in Detroit) DURAGUARD. The mexican ones DON'T (box says hencho mexico) say DUAGUARD. Champion is doing the sub work for AC Delco. Start stocking up...........remember what happened to the PF25's.Save the Wave.>George
Old Sep 27, 2007 | 09:00 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
What is the big deal about where the filter is made. What are you all going to b*tch and whine about when the filter on the car as it comes from the factory is made in Mexico.
Old Sep 27, 2007 | 09:43 PM
blkc6z51's Avatar
blkc6z51
There are parts made in Mexico, on your vette now coming from the
factory. Just look up from under the front end drivers side
tag says made in Mexico.
[IMG][/IMG]
Old Sep 27, 2007 | 10:11 PM
frankmp's Avatar
frankmp
[IMG][/IMG]
Old Sep 27, 2007 | 10:54 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL filters online via links to the left or info in my sig.
Here is more info on the filter:
AMSOIL Ea Oil Filter
Applicable C6 oil filter part numbers carried by AMSOIL:
05-06:
AMSOIL EAO32
Wix 51042
07:
AMSOIL EAO47
Wix 57060
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 28, 2007 | 05:58 AM
Sparky65's Avatar
Sparky65
Give me a break I've heard way too much whining on the Forum lately but you, young man, take the proverbial cake! Give yourself a break and enjoy your Corvette.
To UPF filters???
