Help-Tire Problem
Old Oct 5, 2007 | 06:39 PM
Sativa's Avatar
Sativa
Default Help-Tire Problem
I just got home from picking up my brand new '08 and there is a screw in my tire. Should I pull it out, leave it in, or go to a tire shop?
Old Oct 5, 2007 | 06:42 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Go to either your dealer or call first the Goodyear stores near you if you have EMT tires to see if they're qualified to work on it.
Old Oct 5, 2007 | 06:43 PM
sodapop's Avatar
sodapop
Pull it or not makes no diff, you have run flats. I'd pull it and check dic in alittle while to see if pressure dropped.
Old Oct 5, 2007 | 06:50 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
Don't pull it out. On the Goodyear pamphlet found in your stack of books and papers, you will find an 800# to call for a qualified dealer in your area. The tire will be fixed free of charge.
Old Oct 5, 2007 | 06:58 PM
PappyTinker's Avatar
PappyTinker
From: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
And, if it is not repairable, it will be replaced.
Old Oct 5, 2007 | 07:02 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Perzactly
Old Oct 5, 2007 | 07:41 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Perzactly
whazzat?
Old Oct 5, 2007 | 08:22 PM
Mad*Max's Avatar
Mad*Max
Get it fixed.
Old Oct 5, 2007 | 08:26 PM
rdm1465's Avatar
rdm1465
Leave it in and have tire shop check it, to see if it can be repaired or replaced. They may be run flats, but, what if you can't get to a shop in time. Keep in mind that this is a long week-end too.
Old Oct 5, 2007 | 08:46 PM
Sativa's Avatar
Sativa
Cool, thanks guys. I'm gonna leave it in and take it to a Goodyear shop asap.
Old Oct 5, 2007 | 09:01 PM
Hawk07's Avatar
Hawk07
Take it back to the dealer and ask them to take care of it...
If you ask nicely with a box of donuts you may just get it done for free.
Old Oct 5, 2007 | 09:25 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Originally Posted by AORoads
whazzat?
Sorry for the slang. "perzactly" is used on the forum all the time. Kinda like "Perfect...Exactly".
Old Oct 6, 2007 | 10:02 AM
Sativa's Avatar
Sativa
If I take it to get fixed or replaced do I need jacking pucks?
I have them on order, but they will not be here until Tuesday...
Old Oct 6, 2007 | 10:52 AM
VET4LES's Avatar
VET4LES
Old Oct 6, 2007 | 10:58 AM
Res1cue's Avatar
Res1cue
Default 800 Number
Can anyone post that 800 number to get you screw leak repaired free? How long will they repair the damage for free?
John
Old Oct 6, 2007 | 01:47 PM
SDCEB's Avatar
SDCEB
Go to the tire shop. I got one in my tire, right after I got the car. Discount Tire took it out and it was short enough that there was no problem.
My son got a screw in his C5 tire and we could tell that it was leaking air, so we went back to Discount Tire, they fixed it for free and all is fine now.
Old Oct 6, 2007 | 04:22 PM
Sativa's Avatar
Sativa
John
1-800-786-3528
To Help-Tire Problem
Old Oct 6, 2007 | 04:35 PM
z06Bigbird's Avatar
z06Bigbird
Some for service writer; some for tire guy; some for porter (who washes cars). One doz will do easily. Courtesy is contageous.
They will remember you on your next visit. I bring goodies in regularly. At the Caddy dealer, they all want to wash my cars.
It works, man.
Old Oct 6, 2007 | 10:20 PM
Res1cue's Avatar
Res1cue
Default My recent tire shop visit
I had a screw in my right rear EMT on my 05. The first tire shop said yea they and fix it for 32.00. After I told them they were RFT they said no they could not do it cause all that goo on the inside that allows them to be run flats would prevent them from being patched . I proceeded to turn around and walk right out never looked back.
I called a local goodyear dealer and they said sure they can fix it for 24.00 before I told them they were EMT. Once they heard that they said hold one moment. They came back to the phone with a price of 64.00 to fix my simple screw. I asked why I was be extorted for having RFT, they said the entire shop has to come to a stand still to fix my tire. I call BS and went to the NAPA and got a plug kit for 16.00. Since the tires only have about a 32nd left on them I was not going to pay that just to replace the tires in 6 months.
Old Oct 8, 2007 | 09:10 AM
Res1cue's Avatar
Res1cue
Free flat repair from goodyear dealer only within the first 2/32 of wear or 12000 miles per goodyears dealer. Funny, first 2/32 was probably gone at 2000 miles with the EMT's.
John
