d@%# Gas Door!!
Old Oct 12, 2007 | 08:02 PM
VetteMark's Avatar
VetteMark
Default d@%# Gas Door!!
Anyone have prolems with their Gas Door opening?
I have pushed the release button many times and even tried lightly pulling on the door while pushing the release button and the darn thing just won't open, Last time, I even tried pulling the manual cable and it still wouldn't open!
Any ideas on the cause and is there a fix??!!
Old Oct 12, 2007 | 08:04 PM
C6~Missle's Avatar
C6~Missle
Do you hear the actuator when you hit the button.
Does the door move freely, line up correctly when its open..
johnodrake's Avatar
johnodrake
Moderator
Appears that the catch is hung/stuck. When you get it open, lube it with WD40.
Old Oct 12, 2007 | 08:12 PM
VetteMark's Avatar
VetteMark
Yes and it retracts completely when I finally get it open. While trying to get it open, the door moves as the plunger moves. I pull very hard on the manual cable and it would be hard to believe that it wouldn't release.
I'll give it a try but once it is open, it will open once closed as many times as I care to try. It's only after awhile that it won't open.
It's almost like the door warps a bit and catches on the nut that holds the plunger assembly but I can't verify that for sure.
Old Oct 12, 2007 | 09:02 PM
gath47's Avatar
gath47
I used to not be able to close the gas lid due to the actuator being suck in the withdrawn position, but did learn that a good way to get it unstuck is to open the hatch and close it firmly. This might be of assistance to you since you don't have access to the actuator when the door's stuck shut.
Old Oct 12, 2007 | 09:04 PM
Jet Stream's Avatar
Jet Stream
Mine is just the opposite it FLY'S open.
Old Oct 12, 2007 | 09:12 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Your fly is open ?!
Old Oct 12, 2007 | 10:35 PM
SpankUU's Avatar
SpankUU
I had the same thing happen to me and I checked the emergency cable in the rear hatch and found the cable was pulled out of the holder. Simply push it back and watch the plunger set all the way back where it latches all the way.
Old Oct 12, 2007 | 10:38 PM
z06Bigbird's Avatar
z06Bigbird
Originally Posted by 4 MY EGO
Your fly is open ?!
Flies spread disease; keep yours shut.
Old Oct 12, 2007 | 10:39 PM
z06Bigbird's Avatar
z06Bigbird
Quickest fix is a crow bar.
Old Oct 12, 2007 | 10:54 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I had this problem once. Turned out the cap tether was holding the door shut. The fix was the way the cap tether is positioned when closing the door. If I put it in the lower left corner when closing the door, it always opens the next time. Problem has never repeated.
Old Oct 13, 2007 | 12:00 AM
DP Dave's Avatar
DP Dave
Sorry I can't help with the "Stuck shut" door however I had the "door won't stay shut" syndrone. After being told by Mr. Goodwrench there wasn't anything wrong (still wouldn't close) he finally agreed to replace the actuator and all has been well.
Good luck!
Old Oct 13, 2007 | 07:43 AM
Pipedreams's Avatar
Pipedreams
Good luck!
Stuck open is the more common issue. I found my problem was grime and dirt was in the plunger. Grease or oil is the wrong approach, I cleand it out with some engine cleaner (protecting the painted areas) and it worked perfectly since
Old Oct 13, 2007 | 09:36 AM
VetteMark's Avatar
VetteMark
Hmmm . . . I did have my gas cap replaced under warranty . . . never did it 'til after that.
Old Oct 13, 2007 | 09:43 AM
z51vett's Avatar
z51vett
If it were catching on something it would leave rub marks on paint of the door. The tether idea seems plausable or the manual cable release not working properly.
z51vett
Old Oct 13, 2007 | 09:50 AM
VetteMark's Avatar
VetteMark
z51vett
Checked foe that @ the station after about 5 minutes of frustrated effort when it finally decided to open and saw nothing so I thought then and even more know that it was the tether also. Must investigate this more.
Old Oct 13, 2007 | 09:58 AM
LMBluestreak's Avatar
LMBluestreak
Have you tried having someone push the door in, while you are pushing the release button, and taking pressure off the door the second they hear the "click' inside the door?
06 LMB A6
nl
To d@%# Gas Door!!
Old Oct 13, 2007 | 10:03 AM
VetteMark's Avatar
VetteMark
06 LMB A6
nl
I was trying everything to get the bleepin thing open after having 3 cars set behind me watching my frantic efforts. thought of and nearly resorted to the crow bar method suggested earlier in the thread . . . believe me when I say I was PO'd!!!
Old Jul 18, 2008 | 08:12 PM
Bonnie Egger's Avatar
Bonnie Egger
Okay guys, I got stuck at the gas station today. I couldn't get the fuel door to open but I did hear the click. Went to truck and pulled the manual release which promptly pulled completely out in my hand. It was not connected. How do I get this back in the holder and working again in case I run into this problem again? Car is C5 convertible. Any help woud be appreciated.
Old Jul 18, 2008 | 11:28 PM
SpankUU's Avatar
SpankUU
Your going to have to remove the tire and then remove the wheel liner to get access from the inside of the door.
