This is roughly 30 degrees. Is it that steep? If so, and if the bottom is angled like this one is, you will scrape the front and rear in both directions...
As far as the angle itself, I've seen vettes on the transporter trailers that look to be at a similar angle so it must be OK regarding fluids etc.--but I agree that scraping the air dam etc might be the bigger issue here.
I have a 200 ft driveway with about a 10 degree angle and I scrape the air dam and sometimes the frame under the doors if I am not careful. I guarantee the front or rear will catch on an angle that steep!
I would have to move if I had this type of angle. I agree with the others and do not belive fluid settling would pose a problem, if you were low on fuel you may have a problem starting it though.
