C6 Automatic shift knob rattles
Old Oct 20, 2007 | 11:04 AM
ferrariless's Avatar
ferrariless
3rd Gear
Default C6 Automatic shift **** rattles
I own a 2006 C6 with an automatic and the shift **** button constantly rattles. I took it to the dealer for a different issue and they said there was nothing they could do. Is anyone else having this problem and if so, what is the fix.
Thanks!
Old Oct 20, 2007 | 12:45 PM
toro1966's Avatar
toro1966
I didn't have the same exact problem, but my ebrake was rattling. I tool it apart and put adhesive backed felt (99cents at michaels craft store) in strategic places. Quiet as a mouse now.
Cheers
Old Oct 20, 2007 | 10:14 PM
theofel's Avatar
theofel
St. Jude Donor '10-'13
I have a new 08 and my automatic shift rattles in S mode only. I did not have this prolem in my 06. Going to look at it tomorrow. A little WD40 may help.
Old Oct 21, 2007 | 05:10 AM
shaan's Avatar
shaan
i had the rattiling problem too, i took it to the dealer like 4 times before it got fixed. They installed a new shifter **** and even the new one rattled, they order it again and finally fixed it, i had the e-brake rattling problem and they orderd me a new one too and that got fixed too.
good luck, i hate rattles
Old Oct 21, 2007 | 05:59 PM
Mel 2001's Avatar
Mel 2001
Cheers
Put the felt on one side of the button. It worked for me.
Old Oct 21, 2007 | 06:44 PM
BlackZ51Vett's Avatar
BlackZ51Vett
Dont know if it was the problem with mine but the noise disappeared after having the diff fluid changed and two bottles of the additive put in. I figured it was driveline vibration from the rear clutch packs that was causing the problem. After the fluid was changed, I have had no noise from my shifter........
Old Oct 21, 2007 | 07:21 PM
downrivercorvetteguy's Avatar
good idea
i have the same rattling problem with my '08 shifter.
any instructions on taking it apart or how you made your repair?
thanks
Old Oct 21, 2007 | 10:28 PM
ILLUSHN's Avatar
ILLUSHN
You beat me to it. Mine does it too!
Kind of annoying when you have the radio down low and just want to enjoy your oneness with the car.
Any disassembly tips out there?
Old Oct 22, 2007 | 04:16 PM
Mel 2001's Avatar
Mel 2001
I just put a little pressure between the button and the the holder with a straight edge screwdriver and inserted a one side self sticking felt pad on one side of the button.This eliminated the button from moving from side to side.
Old Oct 23, 2007 | 06:59 AM
theofel's Avatar
theofel
Just finished my big modification to my rattling problem! Seems to have worked.. Just squirted some WD40 and it went away.
Old Oct 23, 2007 | 08:30 AM
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
Mine rattles too, but for some reason only in sport mode. I'll try the WD40.
Old Oct 28, 2007 | 09:43 AM
ferrariless
3rd Gear
Thanks for all the tips! I'm going to try the felt method to tighten up the shift button.
Old Oct 28, 2007 | 10:26 AM
sonny1's Avatar
sonny1
Default shifter rattle
mine rattled too. Dealer replaced the shifter under warranty
To C6 Automatic shift knob rattles
