Selectable Exhaust
Old Oct 27, 2007 | 11:54 AM
betweenvets's Avatar
betweenvets
Default Selectable Exhaust
Is there a selectable exhaust product for a regular C-6 Coupe? I have one on my Chris Craft made by Corsa. I love it. Could there be something similar for the non Z06 Coupe?
Thanks,
No Longer Betweenvets
Old Oct 27, 2007 | 12:26 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
We hear a few are looking at it, here is a thread from member codename Bil Doe that was the first to document this
link
Old Oct 27, 2007 | 04:14 PM
Ron H's Avatar
Ron H
The B&B Fusion is available for the C6 coupe that works like the NPP. You will need to buy the addional parts to make it work.
Old Oct 27, 2007 | 04:18 PM
Pipedreams's Avatar
Pipedreams
Only for the Z06 at this time
Old Oct 27, 2007 | 05:37 PM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
You can retrofit the Z06 Exhaust, NPP Exhaust or the B+B Fusion exhaust to ANY C6. There will be varied amounts of labor needed.
Since the Z06 and Fusion are 3" exhaust you will need an adapter h-pipe.
The easiest would be to get 08 NPP mufflers as they bolt right up to the C6 h-pipe.
Then, you will need to get the vauum piping, vacuum resivour and vacuum solenoid. And then some type of controller to open and close the butterflies.
I did the retrofit of the Z06 Exhaust to my 2005. I lke it a lot.
Since I did a 2.5" to 3" x-pipe I could now bolt the B+B Fusion exhaust right up. I am currently using stock Z06 mufflers.
I developed a wireless exhaust controller that lets me get Full Open, User selectable Rpm Open, and Full Closed modes with the butterflies. I am the FIRST to Offer a RPM Adjustable NPP / Z06 Exhaust Controller.
Its called the NPP / Z06 Ultimate Exhaust Commander. I have the buttons on my homelink programmed so I can switch between the modes right on my visor.
I will add, you dont need to remove the rear bumper to do the retrofit.
You will need to lower the rear sway bar, remove the old mufflers and drop down the h-pipe, and remove the tunnel plate.
If you use the GM vacuum piping, the clips and holders for the vacuum lines are all on the car. You just snap them in place. Its really clean if you use the GM lines.
Then reinstall the tunnel plate, install the mufflers, install the h-pipe, hook up all the vacuum lines, and wire in the controller.
Your Done! Have fun with your new Bi-Mode Exhaust!
I did this install and am always willnig to help anyone who needs info and advice on how to do it.
I wasnt the FIRST to do it, but I am one who is willing to give my help and expertise to anyone who needs it!
Old Oct 28, 2007 | 12:24 AM
Ron H's Avatar
Ron H
I received this email in response to my question concerning the Fusion.
Hello.
Thank you for your interest in our exhaust. The Fusion is available on the Z06 or the 08 C6 w/ the NPP option. As far as the sound difference in the Fusion vs. the 08 w/ the NPP option, our system is much more aggressive and produces 14 additional horse power. Please let me know if I can help.
Thank you,
Mike Boat
23045 N. 15th Ave
Phoenix, AZ 85027
(888) 228-7435 ext 19
(623) 581-5640
mikeb@bbexhaust.com"
To Selectable Exhaust
