Chicklet Removal Tip
Old Oct 30, 2007 | 03:37 PM
Tyson1's Avatar
Tyson1
Default Chicklet Removal Tip
I removed my GM "chicklets" today. I had read several posts on removing them, but I was stubborn and did it differently.
I heated up the badges with a blow dryer then pried the badge off with a plastic freezer scraper ( what comes with some refrigerators ).
I then heated the leftover adhesive up, then scraped off the majority of the gunk with my fingernails.
I then used Windex and a dishtowel to get the residue off.
Just thought I would post this, in case someone was reluctant to use Goo Gone, etc. on their finish. Also, I don't fish and had no fishing line. It was nice to do a "mod" that cost zero dollars.
BTW, the missing badges look great on my LMB!
Old Oct 30, 2007 | 03:39 PM
C6~Missle's Avatar
C6~Missle
3M makes an adhesive remover for automotive paints. It is something I always keep handy.
Old Oct 30, 2007 | 03:41 PM
mdb917's Avatar
mdb917
Thanks for the hints. This is my next Mod and for once it's free
Old Oct 30, 2007 | 03:46 PM
VettinFan's Avatar
VettinFan
Nice tip. Thanks.
I prefer not applying any heat to the paint nor do I use any floss or fishing line on the badge's. I just soak the badge with WD-40 and use a similar plastic scraper, as you described. Once a corner is broken loose, the rest come's off failry easy. I'm not concerned with using Goo Gone, it does the trick with left over stubborn adhesive residue and doesn't harm the finish.
AL
Old Oct 30, 2007 | 06:25 PM
yellowvert's Avatar
yellowvert
Personally, I don't scrape anything on my black paint. I used fishing line but heard even dental floss might work. I also use the 3M adhesive remover. It took a few minutes to get it off but there are NO marks. I just went and looked with a mag glass.
3M adhesive remover is good stuff, just not available at every store. I got mine at an auto paint store. I use it to remove wax before sealing/waxing my car.
Heat from a hair dryer is not hot enough to hurt your paint. The engine generates more heat and so does the Texas sun. Within reason....I suppose if you removed the guard on the hair dryer and nearly touched the coil to the paint you could do damage but if you're that dumb, you deserve to bubble your paint!
My chicklets has a place on the side of the roller tool box with other Corvette emblems, Lotus emblems, etc....Every car I like leaves its mark.
Old Oct 30, 2007 | 06:33 PM
entwood's Avatar
entwood
Old Oct 30, 2007 | 06:34 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
You guys do know that you're making "fake" 05's don't you?
Old Oct 30, 2007 | 06:36 PM
stanleyp's Avatar
stanleyp
GOOD ONE, BRO. High five....
Two zingers with one post.
Old Oct 30, 2007 | 06:38 PM
runutzzzzz's Avatar
runutzzzzz
JACKAL0PE's Avatar
JACKAL0PE
Just wanted to give Grumpy another thread to lock. He looks bored!
Old Oct 30, 2007 | 06:42 PM
VinniesVette's Avatar
VinniesVette
I must be the only one who likes the look of the so called Chiclets. to me it breaks up the monotony of the solid look. I do understand removing it , i like it though. Scraping it off sounds like a recipe for disaster on such a pretty paint job. Can't imagine you can be careful enough not to scratch the paint in the surrounding area.
Old Oct 30, 2007 | 07:12 PM
Eritosthenes's Avatar
Eritosthenes
Wouldn't removing the chicklets invalidate the 100K warranty?
Old Oct 30, 2007 | 08:08 PM
gsport's Avatar
gsport
hmmmmmm.... thinking there might be a market for these for the 05 group....an easy way to up grade their car to look like it's newer than it is...
Old Oct 30, 2007 | 08:20 PM
downrivercorvetteguy's Avatar
i took mine off right away...my wife is a loyal GM bigshot and wasn't thrilled...
if i knew it was going to be this easy i would have taken the body-side moldings off my c5 back in '02.
imho, c5 and c6 corvettes have great lines and and don't really seem to need these add-ons
Old Oct 30, 2007 | 10:48 PM
corvette dave's Avatar
corvette dave
Heat.
Floss badge off.
Heat the goo.
Roll goo off with your fingers.
No chemical remover needed.
BTW: Fingernails can scratch the paint.
Old Jun 21, 2008 | 09:18 PM
alienranch's Avatar
alienranch
Easiest solution:
Simply pull the chicklet back & use a razor blade to cut the backing - obviously be careful of the paint. This takes about 15 seconds. All you have left is the emblem tape. I scraped the majority off with my fingernail & used Goo-Gone for the rest. There was zero negative affect of the Goo-Gone. All-in-all took about 4 minutes & the best mod so far (if you can really call it a mod). Definitely looks cleaner without the coveted GM emblem.
Old Jun 21, 2008 | 09:23 PM
VET4LES's Avatar
VET4LES
To Chicklet Removal Tip
Old Jun 21, 2008 | 09:27 PM
turmat's Avatar
turmat
Dental floss and Goo-Gone, 20 minutes later.....their GONE.
Old Jun 21, 2008 | 09:31 PM
fyreline's Avatar
fyreline
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
I like 'em. I'm keepin' 'em.
Old Jun 21, 2008 | 09:51 PM
GotVett?'s Avatar
GotVett?
If I remove mine, Jake's will take their place.
