C6 Torque Values
Front suspension
Crossmember Mounting Nuts (Use New Nuts)
110 N·m
81 lb ft
Lower Control Arm Ball Joint Stud Nut
First Pass
20 N·m
15 lb ft
Final Pass
80 N·m
60 lb ft
Power Steering Gear Mounting Bolts
100 N·m
74 lb ft
Shock Absorber Lower Mounting Nuts
28 N·m
21 lb ft
Shock Absorber Upper Mounting Nut
26 N·m
19 lb ft
Stabilizer Shaft Insulator Clamp Bolts
58 N·m
43 lb ft
Stabilizer Shaft Link Nuts
72 N·m
53 lb ft
Transverse Spring Retainer Bolts (Use New Bolts)
62 N·m
46 lb ft
Upper Control Arm Ball Joint Stud Nut
First Pass
20 N·m
15 lb ft
Final Pass
50 N·m
37 lb ft
Upper Control Arm Mounting Bolts
65 N·m
48 lb ft
Wheel Hub/Bearing Mounting Bolts
130 N·m
96 lb ft
Rear suspension
Fastener Tightening Specifications
Application
Specification
Metric
English
First Pass
20 N·m
15 lb ft
Second Pass
3 ˝ flats
Final Pass
70 N·m
52 lb ft
Lower Control Arm Cam Bolt Nut - Front
145 N·m
107 lb ft
Lower Control Arm Cam Bolt Nut - Rear
95 N·m
70 lb ft
Outer Tie Rod End Stud Nut
First Pass
20 N·m
15 lb ft
Second Pass
160 degrees
Final Pass
60 N·m
45 lb ft
Rear Crossmember Mounting Nuts
110 N·m
81 lb ft
Rear Suspension Adjustment Link to Crossmember Nut
60 N·m
44 lb ft
Shock Absorber Lower Mounting Bolt
220 N·m
162 lb ft
Shock Absorber Upper Mounting Bolts
30 N·m
22 lb ft
65 N·m
49 lb ft
Stabilizer Shaft Insulator Clamp Nut
95 N·m
70 lb ft
72 N·m
53 lb ft
Transverse Spring Mounting Bracket Bolts
62 N·m
46 lb ft
First Pass
20 N·m
15 lb ft
Second Pass
250 degrees
Final Pass
55 N·m
41 lb ft
110 N·m
81 lb ft
Wheel Hub Mounting Bolts
130 N·m
96 lb ft
Front suspension
110 N·m
81 lb ft
First Pass
20 N·m
15 lb ft
Final Pass
80 N·m
60 lb ft
100 N·m
74 lb ft
28 N·m
21 lb ft
26 N·m
19 lb ft
58 N·m
43 lb ft
72 N·m
53 lb ft
62 N·m
46 lb ft
First Pass
20 N·m
15 lb ft
Final Pass
50 N·m
37 lb ft
65 N·m
48 lb ft
130 N·m
96 lb ft
Rear suspension
Application
Specification
Metric
English
First Pass
20 N·m
15 lb ft
Second Pass
3 ˝ flats
Final Pass
70 N·m
52 lb ft
145 N·m
107 lb ft
95 N·m
70 lb ft
First Pass
20 N·m
15 lb ft
Second Pass
160 degrees
Final Pass
60 N·m
45 lb ft
110 N·m
81 lb ft
60 N·m
44 lb ft
220 N·m
162 lb ft
30 N·m
22 lb ft
65 N·m
49 lb ft
95 N·m
70 lb ft
72 N·m
53 lb ft
62 N·m
46 lb ft
First Pass
20 N·m
15 lb ft
Second Pass
250 degrees
Final Pass
55 N·m
41 lb ft
110 N·m
81 lb ft
130 N·m
96 lb ft
