Trouble Code P0430 ???
Old Nov 12, 2007 | 10:29 PM
Bushong572's Avatar
Bushong572
Default Trouble Code P0430 ???
Can anyone elaborate on this code?
Old Nov 12, 2007 | 10:48 PM
GregGH's Avatar
GregGH
Default google it ??
I did a google on this .... found this right away ---what did you do ?
try it
search for
P0430 OBDII Code
http://www.obd-codes.com/trouble_cod...old-bank-2.php
Old Nov 12, 2007 | 10:52 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Cat inefficiency code. Very common when you install headers with or without high flow cats. I heard it can be tuned out by your tuner.
Old Nov 12, 2007 | 10:58 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
It means you're gonna have to move to Odessa ........................
Old Nov 12, 2007 | 10:59 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
http://www.ls2.com/forums/showthread...23#post2860923
Old Nov 12, 2007 | 11:03 PM
Bushong572's Avatar
Bushong572
Thanks for the help. Google returned a completely different page with very little info when I tried it.
I did install headers 2 months ago............doesn't sound like anything to be worried about. How do I reset it?
Can anyone recommend a basic code reader (not a tuner) that allows you to reset also?
Old Nov 12, 2007 | 11:04 PM
Bushong572's Avatar
Bushong572
I'd rather live in Midland with the check engine light on.....
Old Nov 12, 2007 | 11:48 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Walmart has a code reader for our cars for $69 or so. But you'll be resetting the code every day or so depending upon how your drive pattern is. The computer runs a cat efficiency test every so often when certain drive parameters are met. A tuner can turn it off the testing or just the light for good if you so desire. Some folks (Zig) also reported in the past no codes after ceramic coating their headers to retain heat, and other folks (Spinmonster) report that with proper tuning the code won't be set but the testing can be left on. The topic gets discussion now and again in the C6 Tech section.
Old Nov 12, 2007 | 11:56 PM
Oli1313's Avatar
Oli1313
St. Jude Donor '09
Codes 420-430 are a result of your headers and hi flows. The 02 sensors are detecting too much left over from the cats. Anyway, it happened to me right after the headers were installed. I bought 02 sims from a forum member (cbrf4i1) and now over 8,000 miles w/o a code. Inexpensive fix for a simple problem.
Old Nov 13, 2007 | 12:02 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Old Nov 13, 2007 | 12:12 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
On a more serious note, The best way to eliminate the problem is a good LS2 tune. My suggestion would be to call Bobby @ LG Motorsports http://www.lgmotorsports.com/catalog/index.php (forum vendor/tuner) and set up an appointment to have the car tuned. This will change the settings so that the O2 sensors won't throw a code. Gets rid of the second gear lock out too, etc. Yeah, I know it means driving in to the Dallas area. What can I say ?
Old Dec 26, 2007 | 06:50 PM
CV62's Avatar
CV62
St. Jude Donor '05-'06-'07
I had the same issue about 2 months after after I installed headers as well. Curious if you know if your installer bypassed the rear O2 sensors. Anyhow I purchased the Innova 3100 OBD2 code reader for about $70 and quickly cleared the code and reset the MIL. Hasn't come back in 4 months but ready if and when it does.
To Trouble Code P0430 ???
