My 2008 LS3 displayed the check engine icon. The error was reported as a "fuel mangagement error". The dealership has been unable to get advice from technical support. Does anyone know, or has anyone had the same error message.
I should mention that the check engine icon went on last Thursday afternoon, and then was off when the car was started on Saturday morning.
The easiest thing it could be is the gas cap. It has to be seated completely, tightly or the computer throws a code. You have to put the cap on and spin it it at least 5 or 6 clicks. The code will clear itself it this is the problem. Sounds like it already cleared based on your statement.
Anyone out there with some info-
Sometime your car has a hiccup and throws a code..
It can take several ignition on-off cycles before the error clears.. give it some time.. you might be fine.
