Front underside scraping
Old Nov 16, 2007 | 01:17 PM
mvsette's Avatar
mvsette
Default Front underside scraping
Does anybody know what can be purchased or made to prevent the scratches on the underside of the front of the vehicle (primarily from entering/exiting driveways)??
I looked at the FattDaddys/Mommas but those are only for the C5 and C4... I have a 2008/C6.
I also looked at the Rockerpanel and Skidplate, but am not sure exactly if these are the products that will do the job... I have heard that they are not, although they will protect other areas.
Here is a photo of the front of the car with the red arrows pointing to the bottom where the concern is, which I am sure you all know. The red arrows point to the rubber hanging piece which initially scrapes across the ground, but there are other scrapes on the underside of the front as well.... those are mainly my concern.
Thanks!!
Old Nov 16, 2007 | 01:27 PM
vetdude's Avatar
vetdude
An SUV.
The airdam is made of rubber for that reason. Scraping will not affect its purpose, just looks like crap. Slowing down and entering an incline at an angle will reduce scrapage. They make "frame rail wheels" for the front frame rails but these are designed to allow the front end (under the bumper) to ride up over concrete parking blocks rather than scraping the underside of the bumper.
Old Nov 16, 2007 | 01:31 PM
mvsette's Avatar
mvsette
Cute.... so... does anyone else have a better idea than purchasing another car?
Seriously... thanks!!
chrisf9801's Avatar
chrisf9801
That's the air dam, it's meant to take some abuse. As others will tell you, live with it and when it looks bad enough to you -replace it, it's cheap.
Old Nov 16, 2007 | 01:38 PM
Modshack's Avatar
Modshack
That may be your best bet... We all scrape.
You can raise the car on the suspension using the spring adjuster bolts but you'd eliminate part of the front to rear Rake that is integral to high speed stability.
Others who don't care about such things have done it though..
Old Nov 16, 2007 | 01:39 PM
HawaiiC6's Avatar
HawaiiC6
That airdam is under the car so unless someone lies down and looks under your car they won't see it, look at how low that airdam is it will touch no matter what you do. The smart thing is that GM made it easy to replace and it is cheap.
Now on the other hand you could have a ZO6 and scrap the front spoiler lip...ouch.
Old Nov 16, 2007 | 01:40 PM
maxp's Avatar
maxp
Old Nov 16, 2007 | 02:04 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
If you have scrapes on the underside of the bumper and not just the air dam that is usually caused by pulling up on wheel stops when parking. In that case you need to get use to not pulling up so far.
Old Nov 16, 2007 | 07:21 PM
ctspirit's Avatar
ctspirit
Just use the airdam retractor button before entering suspect driveways....thats what I do!
Old Nov 16, 2007 | 07:25 PM
ctspirit's Avatar
ctspirit
sorry...I was confusing my imaginary corvette options with the hydraulic jackplate blinker lever on my boat
Old Nov 16, 2007 | 07:41 PM
DAYCRZ's Avatar
DAYCRZ
I am kind of surprised your 08 is giving you fits on "scrapeing" on the air dam
My C5 scrapped on everything and you just had to deal with it
My 08 because the nose of the car is shorter does not scrape near as much, Boy I can't wait to lower this puppy
Dan
Old Nov 16, 2007 | 08:55 PM
Vet's Avatar
Vet
Originally Posted by Modshack
...You can raise the car on the suspension using the spring adjuster bolts but you'd eliminate part of the front to rear Rake that is integral to high speed stability. Others who don't care about such things have done it though..
Yes, you can raise the suspension... even a mere 1/4" raise surprisingly eliminates a good degree of common scrapes. Rake does not change as long as you raise both the front and rear by the same amount.
I've raised my car almost 3/4", kept rake the same, car is still dead solid and handles beautifully at 120mph (after an alignment).
I also found that in my daily routine travels, the raising has reduced air dam scraping by easily over 75%... I went from hearing scraping quite regularly to now rarely hearing it at all (except in "extreme" cases of course such as steep driveway entrances, tall speed bumps, etc.)
As others have said, you do not even see the air dam anyway, plus it was DESIGNED to be scraped often, etc... so don't worry about it... or raise the car.
I never really minded the air dam scraping in general, I raised my car mainly to keep from encountering serious damage (breaking radiator supports or worse) due to road irregularities, road debri, construction areas, ferry ramps, unpaved parking areas, etc... but the raise ALSO eliminated air dam scrapage when entering / leaving my own driveway, a nice plus... because I hated making that scrape noise all the time in front of my house, especially late at night, I'm sure the neighbors did not like it... but no longer a problem.
Old Nov 16, 2007 | 09:03 PM
Leprkon's Avatar
Leprkon
RPI Designs makes a wheel kit to help reduce the scraping, but I can't vouch for how effective it is or how good the company is... just don't know...
http://www.rpidesigns.com/shop/item.asp?itemid=596
Old Nov 18, 2007 | 12:09 PM
calemasters's Avatar
calemasters
I purchased some 1/2" wide body side molding at PEP Boys, cut to length and installed longitudinally at about 1' intervals across the lower part of the front fascia. The molding are not visable from standing heigth.
To Front underside scraping
