Tire pressure?
Old Nov 18, 2007 | 07:13 PM
VetteManRay's Avatar
VetteManRay
From: Forest Hill, (Out in the country), north of Baltimore. Maryland. Land of "Pleasant Living" with my Corvette, steamed crabs & crab cakes.
Default Tire pressure?
I have an 08 A6 coupe with Goodyears. I try to keep the air pressure at 32lbs. What is the recommended air pressure? How often should I check the air pressure? Does it matter that in Maryland it is starting to get colder?
Old Nov 18, 2007 | 08:03 PM
Vette_DD's Avatar
Vette_DD
The sticker on the driver's door jamb says 30 lbs. Since tire pressure goes down about 1 psi for every 10 deg. drop in temp., I usually add air to mine about 2 or 3 times during the winter so they stay at 30 lbs. when cold.
I'd check the press. via the DIC about once a week, again an extra time when the temps drop much to stay.
Old Nov 18, 2007 | 08:04 PM
johnodrake's Avatar
johnodrake
Moderator
Old Nov 18, 2007 | 08:11 PM
havesleep's Avatar
havesleep
30 psi, I have one of the tire gague that banances two tires at a time.
Old Nov 18, 2007 | 08:16 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Stay with 30 psi. If you over inflate, you'll wear out the centers
Old Nov 18, 2007 | 08:18 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As Jim indicated, tire pressue is not a set it and forget it item. Tire pressure should be checked when cold (cold tires, not driven).
You should keep your tires at 30 psi cold.
Tire pressure will drop approximately 1 pound for each 10 degree drop in temperature. It will inversly raise approximately 1 pound for each 10 degree rise in temperature. If you check your tires in the afternoon sun one day and fill them to 30 psi and then overnight the temperature drops 20 degrees they will be down about two pounds when you check them in the morning
Old Nov 18, 2007 | 08:28 PM
rjbraud's Avatar
rjbraud
Old Nov 18, 2007 | 09:01 PM
GotVett?'s Avatar
GotVett?
Mine seems to ride better with 32.
Old Nov 18, 2007 | 09:13 PM
GaussianMist's Avatar
GaussianMist
I try to keep mine at 30 PSI. How accurate is the DIC, it seems to be 1-2 lbs lower? I have a digital tire pressure gauge.
Old Nov 18, 2007 | 09:16 PM
GaussianMist
it will also ride too hard and in my opinion the steering seems to float a bit, just my personal preference.
Old Nov 18, 2007 | 09:35 PM
scrutator's Avatar
scrutator
Any different for the Firestone Wide Ovals? When I first had them mounted I think the dealer had 'em at 36. When the tires got warm one went over 40 PSI and the dash indicator gave me a high-pressure warning.
Old Nov 18, 2007 | 09:58 PM
keyplyr's Avatar
keyplyr
In San Diego the temp has recently plummeted to a chilling 70° so I now keep the tires at 31lbs.
Old Nov 18, 2007 | 10:02 PM
Vette_DD's Avatar
Vette_DD
I would frequently see a difference of 2 lbs in my 05 silver coupe, but never more than 1 lb difference in the 06 coupe. I usually go by what I measure with the tire gage, since it will show me 1/2 lb, where the DIC won't.
Old Nov 18, 2007 | 10:38 PM
VET4LES's Avatar
VET4LES
I watch my tire pressure like a hawk and for the first year or so kept them at 30 cold. At around 12,000 miles the rears started to show wear in the center of both tires. I have lowered them to 28 psi and will see if they even out. I have read that the C5 guys have learned to run 28 psi on the rears for best wear.
Old Nov 19, 2007 | 08:58 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
My experience also. Actually, I think 32psi running temp is best, corresponding cold temp is determined by trial and error, and changes with the seasons. 30psi cold works ok for me in the winter but I need to drop to 28 cold in the summer, when road temps can hit 130 degrees here in Florida.
Old Nov 19, 2007 | 09:05 AM
Mike Campbell's Avatar
Mike Campbell
One thing is for sure, that the DIC is always 2/3 lbs. low. I try to keep 30 in them but it drops like a stone in cold weather.
Old Nov 19, 2007 | 09:54 AM
C8-Vette's Avatar
C8-Vette
I also have the Firehawks. Stay with the vehicle recomended 30 PSI.
To Tire pressure?
Old Nov 19, 2007 | 11:04 AM
overrev64's Avatar
overrev64
Tire pressure recommendation stickers are vehicle specific, not tire brand specific.
I don't agree. I have found my tire pressure readings to be accurate. However, I have found that different external gauges register different readings.
Old Nov 19, 2007 | 11:06 AM
carpe dm's Avatar
carpe dm
32lbs psi (cold) seems best to me.
Old Nov 19, 2007 | 12:42 PM
10mikeymike's Avatar
10mikeymike
Default Tire Pressure
I'm happy to see this post as Ive recently installed BFG KDW2's and I'm still in the process of finding the "right" pressure to run with them. I previously ran 28 PSI cold year round on my Goodyears and in 12K miles they showed virtually no wear. With the BFG's I started out with 30 PSI cold, but I've recently reduced that to 29 PSI. With temperatures hovering around the mid 30's to low 40's now, that results in a 31 PSI warm tire driving pressure. I have an F55 suspension and one thing I noticed with the Goodyears was that 1 or 2 PSI made a noticeable difference in ride quality regardless of whether the car was in Tour or Sport mode. I'll drive my car on cold dry days in the Winter, so I'll continue in my efforts to find that "comfort/handling/wear" compromise with the new tires. BTW, I have a new digital tire gauge and a 25 year old Sears dial type gauge. The Sears gauge is dead nuts accurate with the DIC display or they're both wrong.
