I have a downward slop drive into the garage and am concerned about clearing that front chin as I pull in. About how much clearance is there? Anyone know how far past the front wheels the spoiler is? I am trying to calculate if I will have a problem before they pour cement so I can see if it will be possible to fix a problem before it is a problem. I plan to order in Jan. Thanks
The leading edge of the plastic chin spolier is approximately ten inches in front of the front edge of the tire and is 3 inches from the ground. . . the "hard parts" of the car-- radiator supports-- have a clearance of 5 inches at the front.
The spoiler isn't articulating per se, but is obviously flexible, and it's fairly easy to replace any of the 3 pieces. Center section is about $60, sides are $20.
It's a bit unnerving frankly, because it scrapes on just about everything, but has enough flexibility that little damage is done as a general rule - - it's just that nasty scraping sound that's can make you nuts..
