Interesting door lock problem
Old Nov 19, 2007 | 08:11 AM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Default Interesting door lock problem
This morning, parking the car at work , I accidentally bumped the off switch twice in a row quickly. The car went into accessory mode without me being aware of it. I pushed the door unlock button to exit and nothing happened! Without panicking, I looked and saw I was in acc mode and pushed the off button again to turn the car off, but the door would not unlock. So, I restarted the engine, and then shut down properly. Then the door unlock button worked properly. Wierd.
Just in case the same thing happens to you, I guess you have to restart and shut down properly to reboot the system.
GM
Old Nov 19, 2007 | 09:35 AM
srpbaer's Avatar
srpbaer
GM
NOPE...merely hit the door locks button to unlock and exit!!!! Been there and done that and have the shirt to prove it!!!
Old Nov 19, 2007 | 11:03 AM
VetteManRay's Avatar
VetteManRay
From: Forest Hill, (Out in the country), north of Baltimore. Maryland. Land of "Pleasant Living" with my Corvette, steamed crabs & crab cakes.
Default Thanks for sharing
Old Nov 19, 2007 | 11:08 AM
carpe dm's Avatar
carpe dm
Did you try the "emergency" door lever, on the floor?
Old Nov 19, 2007 | 11:20 AM
MaxOctane's Avatar
MaxOctane
I think his point was that the unlock button did not work in acc mode, and NOT that he couldn't exit the car.
Old Nov 19, 2007 | 11:59 AM
Shrike6's Avatar
Shrike6
Somba master
That's right, I wasn't going to bail out unless it was unavoidable!
GM
Old Nov 19, 2007 | 12:07 PM
dgrant3830's Avatar
dgrant3830
We'll have to try that and if we all have that issue, I would suspect that GM will have to do a reprogram the BCM to fix.
Old Nov 19, 2007 | 12:10 PM
Shrike6's Avatar
Shrike6
Somba master
Yeah, let me know if it does the same for you. I have an early '06.
GM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Gary,
I've had similar problems with my 05 MN6. A few times I had to remove/distance the FOB by getting out of the car and walking away.
Once it would not start at all. Towed to the dealer. They replaced the column lock assy for the fix. If still in warrantee try the dealer.
To Interesting door lock problem
