What Goes Thump
Old Nov 19, 2007 | 12:55 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
Default What Goes Thump
All of a sudden I'm getting an annoying llittle thump or dull popping noise at very low speed in my 05 coupe. It's not loud, not a constant rattle, and sounds almost like a very small suspension pop that seems to be coming from under my feet - maybe the fender well area. I've put it on the rack, but can find nothing that might be the cause. I did install Z51 sway bars recently and it has started since then, but I'm not sure there is a connection. Even though the front sway bar is now extremely close to the bottom of the radiator fan shroud I don't think that's it and I can't find another candidate. Is there something under the fender well that could be lose?
Old Nov 19, 2007 | 02:45 PM
dbratten's Avatar
dbratten
I have the same thing (perhaps) that sometimes is more of a rattle. It's really noticeable in slow turns on rough surface. It sounds like it's coming from the bell housing (but could be fenderwell, too) -- like some rod or tube bumping against something. I thought it may be the tran's cooler lines hitting somewhere but I can't reproduce the sound when up on my lift. I tightened up the suspension with COs and sways but they aren't hitting anything that I can find. I thought of going to the dealer and having the tech ride along but that may be a waste of time.
--Dan
Old Nov 19, 2007 | 03:16 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Tires - slow turns when cold
Old Nov 19, 2007 | 03:20 PM
dbratten's Avatar
dbratten
Nope, not even close. Hot or cold -- no difference. Besides, we're in CA and FL where it doesn't really get cold.
--Dan
Old Nov 19, 2007 | 03:21 PM
coastalcarolina's Avatar
coastalcarolina
From: Myrtle Beach & Greenville, SC -- Hung Like a Republican -- Network Admin/IT
Interesting take....
I've had cheaper tires on other cars make similar weird noises....
Guys, what kind of tires do you have?.... that could be your problem.. possibly.
Old Nov 19, 2007 | 04:38 PM
TCKT B8's Avatar
TCKT B8
I'm virtually positive its not tires. I have the original
Goodyear tires (7,100 miles). The noise only occurs at very slow speeds, does occur when turning, and sounds like something bumping against the plastic fenderwell housing.
Old Nov 19, 2007 | 04:55 PM
MaxOctane's Avatar
MaxOctane
I think I may have the same thing. Only rarely, and only when turning I'll get a thump in the suspension. Sounds like it's coming from the front.
I've got original supercar tires that are almost done. I can't imagine the noise coming from the tires.
Old Nov 19, 2007 | 07:13 PM
mcwire's Avatar
mcwire
I had same problem, after installing Z51 sways. It was from the fact that I did not tighten the links enough. Double check them both sides. I'm guessing that's your problem. If I remember, you need a #40 torx and a ?? MM wrench.
Old Nov 19, 2007 | 08:24 PM
Wayne88's Avatar
Wayne88
When I installed the Corsa Sports, that happened to me. I did not tighten the bolts on the rear sway bar enough.
Old Nov 19, 2007 | 08:39 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
If you recently installed a new sway bar, I'd have to say it's one of two things.
#1. When installing the new sway bar, the end links were put in a bind to get the bar in. Re-center the bar, re-align the links.
#2. If you have stock sway bars and you hear a "popping" sound. Bad links. Tightening the links does not help. They have play where the sway bar connects to the top portion of the link. Easily diagnosed, take a pry bar and wedge up against the bar at each end. You'll hear the same "popping" sound.
Took me two months to troubleshoot this problem. Stock links are junk. I recently installed the Pfadt bushings and heavy duty links.
Old Nov 19, 2007 | 11:09 PM
siffert's Avatar
siffert
Default What Goes Grind
I have a different problem. I have a traffic circle neaby which I use as a "skid pad" occasionally running counterclockwise at night. Anyways, traveling around it at around 35-40mph and at around .7 g's I hear a grinding type noise coming from what seems to be the passenger right rear loaded wheel area. It is not tire squeal or clunk or chatter or popping and I dont hear this sound under normal driving conditions or when running around the same circle at low g's. Any idea what's up? Could it be the be my positraction clutches grabbing? I have the FE1 base suspension.
Old Nov 20, 2007 | 01:19 AM
mk2pilot's Avatar
mk2pilot
Sounds similar to my complaint, along with a popping sound like when something is binding and just lets go. Never had the sound until the dealer put it up on the lift for an oil change. Now, it's all the time when going slow with the least little turn of the wheel.
To What Goes Thump
