Base Suspension
Old Nov 20, 2007 | 02:42 PM
marc4427's Avatar
marc4427
Default Base Suspension
The 1st ever vette Im looking to get would have base suspesion, is that ok? Im not looking to race or track, just pleasure driving. Is the base susp comfortable? Any replies will be appreciated.
Old Nov 20, 2007 | 02:52 PM
CraigE's Avatar
CraigE
The base suspension is very comfortable.I added Z51 sway bars, Pfadt swaybar bushings, and Koni FSD shocks. The car is even more comfortable now, and the handling is fantastic.
So you can always improve it.
Old Nov 20, 2007 | 02:53 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Good luck in your search. You should have no problems with the base suspension. For what it is, it is quite capable and just fine on the comfort scale.
Modshack's Avatar
Modshack
I did the same only with Bilsteins... It's about perfect now!
Old Nov 20, 2007 | 02:58 PM
marc4427's Avatar
marc4427
thanks for all your input.
Old Nov 20, 2007 | 03:00 PM
Ozone's Avatar
Ozone
Can you add the Z51 swaybars to the F55 and will it improve anything? Sounds like a fairly inexpensive mod.
Old Nov 20, 2007 | 03:03 PM
Modshack's Avatar
Modshack
Sure...Lots here have done it with great results....
Old Nov 20, 2007 | 03:04 PM
millpond's Avatar
millpond
My first Vette is an '05 with the base suspension, and it is perfect for me ( I don't track it). It is more comfortable than my '08 Accord... Probably because the suspension is so much tighter than the Accord.
Old Nov 20, 2007 | 03:05 PM
C6~Missle's Avatar
C6~Missle
Sounds like the base suspension should work fine for your needs..
Old Nov 20, 2007 | 03:15 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
The base suspesion is fine and would be very comfortable.
Old Nov 20, 2007 | 03:29 PM
JFFVETTE's Avatar
JFFVETTE
Mine's a base suspension model, and I have no complaints. It's hard to believe how well it actually does handle and ride, considering how low it sits to the ground.
Old Nov 20, 2007 | 03:32 PM
adconti's Avatar
adconti
Base is great, and if you feel the need, the mods to bring it up to a Z51 feel will cost about 300-500$ for the sways, and shocks, but definitely drive it first. You will likely be happy with the base anyway. I have the F55 FWIW
Old Nov 20, 2007 | 09:31 PM
1yy07vette's Avatar
1yy07vette
test drove z51 and base. the z51 was to bumpy for me.
Old Nov 20, 2007 | 09:36 PM
Vette_DD's Avatar
Vette_DD
I've had both the base suspension (05 coupe) and the F55 suspension (06 coupe). We have pretty good roads most places where I drive and there's very little difference between base suspension and tour mode with the F55 on those roads.
I can tell a little difference on bad roads, but not much. The base suspension was a very comfortable ride. The main reason I now have the F55 suspension is that was on the car that I bought off the dealer's lot.
Old Nov 20, 2007 | 09:55 PM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I am very satisfied with the base suspension in my C6.
Old Nov 20, 2007 | 09:58 PM
tfkrato's Avatar
tfkrato
This post may be of interrest
http://forums.corvetteforum.com/show...hlight=tfkrato
Old Nov 20, 2007 | 10:00 PM
backpack's Avatar
backpack
Base suspension on my 2001 coupe was just fine ---but--- sometimes I about got killed by road intrusions (pot holes, bridge edges, etc). Now have the F55 on my 05 and it takes the back breaking edges out of all those pot holes. I love it but if your roads are OK, you don't really need the F55.
To Base Suspension
Old Nov 20, 2007 | 10:11 PM
cthusker's Avatar
cthusker
we have some very crappy roads around here so I went with the F55. However the base suspension is just fine also....
Old Nov 20, 2007 | 10:15 PM
goatts's Avatar
goatts
Base suspension is QUITE stiff for the street. I autox every couple of months and it works great for that too. Very little roll on hard turns.
Old Nov 20, 2007 | 11:58 PM
mcwire's Avatar
mcwire
I have added Z51 sways to F55 suspension & can feel the difference, in hard corners.
