removing e-brake button
Old Nov 20, 2007 | 05:47 PM
daveboy's Avatar
daveboy
Default removing e-brake button
Would like to remove my e-brake button to paint it. How does it come off? I tried pulling and that didn't work, but I didn't want to break it either.
So am I not pulling hard enough?
daveboy
Old Nov 20, 2007 | 05:48 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Remove the "grip" first. Then pull on the button, it will pop off.
Old Nov 20, 2007 | 05:57 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
daveboy
You need to remove the handle to get at the button. There is a screw at the base of the handle. Once that is removed, while seated in the drivers seat you need to grasp the handle with your right hand and pull upward and outward (towards the passenger dashboard) quite firmly. The button is on a detent and the force of the handle sliding foward will cause it to pop off but it takes a bit of force.
I forgot to mention that you will need to slip the boot off the base of the handle to reveal the screw. It is simply a philips head screw.
Old Nov 20, 2007 | 06:10 PM
daveboy's Avatar
daveboy
I will give that a try.
daveboy
To removing e-brake button
