Strange HID problem
Old Nov 23, 2007 | 08:55 PM
viabono's Avatar
viabono
Default Strange HID problem
I’m experiencing a problem with the driver side HID headlight. Once the lights are on I am noticing a bursting effect from the driver side light followed by an almost imperceptible dimming until the next burst when the light appears to be at 100% again. It’s similar to the initial burst seen when the lights are first turned on. This cycle occurs continuously and on all road conditions. Has anyone else experienced this? Is it the bulb or a problem with the HID electrics?
Old Nov 23, 2007 | 10:46 PM
mpuzach's Avatar
mpuzach
All together, my wife and I have owned 5 cars with xenons and I've never heard of or experienced the problem you're describing. Sorry I can't offer you any info.
Old Nov 23, 2007 | 10:52 PM
Jet Stream's Avatar
Jet Stream
It sounds to me like you might have a bad ballast.
Old Nov 23, 2007 | 11:07 PM
Colby 04's Avatar
Colby 04
THAT.....was the most worthless post that I have ever seen
Old Nov 23, 2007 | 11:32 PM
mpuzach's Avatar
mpuzach
Glad you enjoyed it, The point was that whatever is causing the problem for the OP, my thinking is that it's not something that's very common. AFAIK it's never been reported here before.
Old Nov 23, 2007 | 11:47 PM
johnodrake's Avatar
johnodrake
Moderator
I've never heard of that before either, but I agree with Jet Stream, sounds like a ballast issue. I would think you could swap the ballast and see if the problem follows.
Old Nov 24, 2007 | 12:27 AM
Colby 04's Avatar
Colby 04
No offense intended....I just busted out laughing when you posted that you basically have never had the problem and have no relevant advice to offer
Old Nov 24, 2007 | 12:31 AM
Wethingtonvette8093's Avatar
Wethingtonvette8093
I had one do this on my BMW. Ballast it was
Old Nov 24, 2007 | 03:29 AM
shopdog's Avatar
shopdog
Its the ballast.
Old Nov 24, 2007 | 05:15 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
IMHO this is a very relevant answer. One of the first things people want to know about their issue is whether it is a common problem experienced by other owners and the known fix. He addressed both in his answer.
Old Nov 24, 2007 | 05:36 AM
jojog's Avatar
jojog
They can be strange. When I did my museum delivery my right light strobed like a Police car - the factory replaced the entire assembly. Good luck with your car!
Old Nov 24, 2007 | 02:55 PM
viabono's Avatar
viabono
Thanks everyone...I appreciate the help and the info regarding the ballast.
Old Nov 24, 2007 | 05:21 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
SInce the igniter is built into the ballast that is your problem.
To Strange HID problem
