sill plates
Old Nov 26, 2007 | 04:40 PM
c6chaz's Avatar
c6chaz
Default sill plates
have o8 sill plates for my 07 do i install over the plain black and how do i install two sided paper bottom has glue strip do iuse a solution of soap and water to get in place will this makeglue not stick
Old Nov 26, 2007 | 05:18 PM
JLMounce's Avatar
JLMounce
The 07 door seals look to be a vinyl material.
A heat gun, and some soapy water will probably remove them. I wouldn't lay the new seals over the old as it'll likely lose adhesion eventually.
After you remove the old seals, just make sure the mounting surface is clean and dry.
Old Nov 26, 2007 | 05:21 PM
calemasters's Avatar
calemasters
It took me about 40 minutes/side to remove the adhesive, after the factory appliques were removed.
Old Nov 26, 2007 | 05:23 PM
Gillvette's Avatar
Gillvette
I heated mine up w/ a hair dryer and they peeled right off, then I stuck the new ones on.
Old Nov 26, 2007 | 05:36 PM
c6chaz's Avatar
c6chaz
Default sills
how do i get them in the right position
Old Nov 26, 2007 | 05:39 PM
Gillvette's Avatar
Gillvette
I simply eyeballed mine and they look perfect.
Took me about 10 min.'s to do both sides.
Old Nov 26, 2007 | 05:45 PM
petiebear's Avatar
petiebear
Before you remove the old ones, put some masking tape on the ends and bottom. Then you can get them back perfect. There is a driver and passenger side so be aware.
To sill plates
