memory savers while battery disconnected
It would really be a waste of your money. In the spring when you fire it back up you just need to reindex the windows. You won't loose anything else.Window Indexing
This feature automatically lowers the window a small
amount when the door is opened. When the door
is closed, the window will raise to its full up position. If
either window does not index properly, it could be due to
loss of power. Before returning to your dealer/retailer
for service, perform the power window initialize
procedure.
Power Window Initialize
After a power reconnect such as battery replacement,
the window index-up feature will not function until
the system is initialized.
Once power is restored:
1. Close the door.
2. Raise the window and hold the switch up for three
seconds after the window is closed.
3. Release the switch, then hold the switch up again
for three seconds and release.
GM
Non were a big deal. Your car will sleep well.
To the other question the other settings the OP has asked about should not be affected if the car has shut down properly. Memory and such can be affected in the event of a catastrophic loss of power with the car not in a shut down state much like what would be seen with a DBS car.
Once shut down, all of these items should be stored for the car to come out of hibernation with little or no affect other that the state of the windows index.
Mike
