Programming name into cluster
Old Dec 1, 2007 | 03:52 PM
Night Stalker's Avatar
Night Stalker
Default Programming name into cluster
I have seen several 05+ corvettes that had the owners name or a message come up when they start the car. How do I do this?
Old Dec 1, 2007 | 03:55 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It is in your owners manual under DIC Vehicle Personalization
Personalize Name: This option allows you to type in a
name or greeting that will appear on the DIC display
whenever the corresponding keyless access
transmitter (1 or 2) is used or one of the memory
buttons (1 or 2) located on the driver’s door is pressed.
Press the OPTION button until PERSONALIZE
NAME appears on the display, then press the RESET
button to scroll through the following modes:
• YES
• NO (default)
If you choose YES, you can type in a name that will
appear on the DIC display.
To program a name, use the following procedure:
1. Enter the PERSONAL OPTIONS menu and select
the driver number (1 or 2) that you would like to
program by following the instructions listed
previously under “Entering the Personal
Options Menu”.
2. Press the OPTION button until the PERSONALIZE
NAME option appears on the display.
3. Select YES under PERSONALIZE NAME by
pressing the RESET button.
4. Press the OPTION button and a cursor will display
where you can insert a letter.
5. Press the OPTION button again until the letter you
want is displayed. To scroll through the letters
faster and without a beeping noise, keep the
OPTIONS button depressed. There is a complete
alphabet and a blank space available.
6. Then press the RESET button to select the letter of
your choice and proceed on to the next space to
the right.
If you make a mistake and would like to clear or
replace a letter, perform the following steps:
6.1. Press the RESET button to reach the letter
you would like to change.
6.2. Press the OPTION button to scroll through
the letter choices.
6.3. Press the RESET button to select the
letter and proceed on to the next space
to the right.
7. Repeat Steps 5 and 6 until the name or greeting
you want is complete. After the name or greeting
is complete, keep pressing the RESET button
until the display turns blank and exits out of this
option. You can program up to 20 characters.
If you choose NO, this option will turn off.
If a customized name or greeting is not programmed,
the DIC display will show Driver 1 or Driver 2 to
correspond with either the number on the back of the
keyless access transmitter (1 or 2) that is being used or
to the memory button (1 or 2) that is pressed.
PERSONALIZE NAME is the last option available to
program in the PERSONAL OPTIONS menu. Pressing
the OPTION button after this setting will exit you
from the PERSONAL OPTIONS menu. The last item
you were in prior to entering PERSONAL OPTIONS will
then display on the DIC.
Old Dec 1, 2007 | 03:57 PM
C6NRED's Avatar
C6NRED
OK, the reply above was LOTS better than mine.... (my directions deleted)...or you could just have read your owner's manual......Mine now says
Thank you Lord.
Old Dec 1, 2007 | 03:58 PM
Night Stalker
thanks for the fast replies!!!
Old Dec 1, 2007 | 03:59 PM
RicK T's Avatar
RicK T
If you have an owner's manual, it's on page 240.
To Programming name into cluster
