Valve Stem Caps
Old Feb 13, 2008 | 11:47 AM
cthusker's Avatar
cthusker
Originally Posted by Pipedreams
Correct, has to do with incompatible metals causing corrosion
I put some on my 4runner with disastrous results! The fancy caps WELDED themselves to the valve stems. There was simply no way to get 2 of them off when I needed to service the tires. Wound up having to replace 2 internal tp pressure monitors because they broke while trying to get the valve caps off. I also had used never seize on but it didn't work......
I will never EVER use them again because it turned into a VERY expensive exercise.
Old Feb 13, 2008 | 11:57 AM
dvilin's Avatar
dvilin
This should do it!!
Originally Posted by talon90
What you'd be facing is galvanic corrosion. It is caused by the reaction of two dissimmilar metals in contact with each other. The table below shows the reaction potential of the materials which will form the anode and cathode in the case of assembly. Of note is the distance the metals are apart.
In the case of Chrome plated caps, they will actually reduce the potential for galvanic corrosion as they are closer together on the table (as long as the chrome plating on the threads holds up) once it fails then the base metal comes in to play. The elements at the top half of the table are more active (anodic) the elements at the bottom of the table are more passive (cathodic).
Electrode Potential at 77 F (25 C)
Anodic end (this is where the corrosion occurs)
Element Standard Electrode Potential (Volts)
Lithium -3.045
Potassium -2.920
Sodium -2.712
Magnesium -2.340
Beryllium -1.700
Aluminum -1.670
Manganese -1.050
Zinc -0.762
Chromium -0.744
Iron; Mild Steel -0.440
Cadmium -0.402
Yellow Brass -0.350
50-50 Tin-Lead Solder -0.325
Cobalt -0.277
Nickel -0.250
Tin -0.136
Lead -0.126
Hydrogen reference electrode 0.000
Titanium +0.055
Copper +0.340
Mercury +0.789
Silver +0.799
Carbon +0.810
Platinum +1.200
Gold +1.420
Graphite +2.250
Old Feb 13, 2008 | 12:00 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
I had all 4 of my aluminum ones stolen, Need to get new ones.
GM
Old Feb 13, 2008 | 12:01 PM
gsport's Avatar
gsport
Originally Posted by gbgary
electrolysis
i thought that is what women use to remove unsightly hair...
Old Feb 13, 2008 | 03:13 PM
vdavenp802's Avatar
vdavenp802
Originally Posted by tjackson82
The amazing things I learn on this forum? And I was silly enough to thing caps are caps!
.remember knowledge is power.
Old Feb 13, 2008 | 03:27 PM
Bandit1's Avatar
Bandit1
Ran the chrome caps on my 99 for six years and am running them on my 06, both with no problems.
Old Feb 13, 2008 | 03:31 PM
VET4LES's Avatar
VET4LES
electrolysis
I don't think it's a big problem with valve stem caps.
Old Feb 13, 2008 | 04:05 PM
djfullshred's Avatar
djfullshred
Any particular reason you needed to attack my post? I was simply trying to provide complete information. I'll not bother to post in the future if it upsets you so much....geez.
You made someone think, and they didn't like it. A lot of people on the Internet take offense to someone bringing actual technical facts that require thought into a discussion.
Old Feb 13, 2008 | 04:40 PM
Harry2's Avatar
Harry2
talon90,
I have always enjoyed your comments based on your Vette expertise. Please ignore the previous post, the vast majority of us do appreciate your posts!
Old Feb 13, 2008 | 04:45 PM
chet b's Avatar
chet b
I learned something new about valve stem caps today.
Old Feb 13, 2008 | 04:48 PM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
talon90,
Keep posting ... I usually learn something.
BTW, as an engineer I agree with the technical content, but I ran chrome caps on my C5 for 9 years (97-07) and on my C6 for a year with no worries ... and this on the beach in Florida!
Old Feb 13, 2008 | 05:23 PM
User 020720's Avatar
User 020720
Originally Posted by Wayne O
BEZ06 is the resident expert when it comes to tire pressure sensors. His instructional videos on TPMS tools are an invaluable resource for all forum members...he knows what he's talking about!
Isn't that the truth, his posts were very helpful when I was researching and purchasing my TPM reset tool (the Bartec Trackside).
Old Feb 19, 2008 | 10:36 PM
  #33
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Great info here!
Old Feb 19, 2008 | 10:46 PM
  #34
Vette_DD's Avatar
Vette_DD
I guess I'll take my chances and continue to use the ones GM put on my car at the BG plant.
Old Feb 19, 2008 | 10:54 PM
  #35
jimmie jam's Avatar
jimmie jam
talon90,
DITTO.
Old Feb 19, 2008 | 11:03 PM
  #36
Tom_Slick's Avatar
Tom_Slick
Originally Posted by Kreuzen
There is a reference in the owners manual - or at least in my 05 manual. Basically, the stock cap works/acts as an antenna for the sensors.
I used to get a lot of false readings(driving along, warning light comes on, tire pressure down to 15%!) I pull over check the pressure with a gauge and find out it was a false alarm... Since I've read about this and put the factory caps back on... no more false alarms! These are the caps I was using... Chrome plated brass...
Old Feb 19, 2008 | 11:19 PM
  #37
SpryGeezer's Avatar
SpryGeezer
Subaru says a non-OEM valve cap "may" cause signal interference .......on Subarus.
http://endwrench.com/images/pdfs/KeepEWAug07.pdf
From Endwrench page 11.
"...Also, the valve stem of the wheel sensors serves as the
transmitting antenna, so don’t replace the original valve caps
with any other type that may interfere with the signal. ■
Always follow...."
