Hatch hits roof
Old Dec 2, 2007 | 01:16 PM
V8 Juice's Avatar
V8 Juice
Default Hatch hits roof
Anyone experience the problem of the hatch hitting the center rear of the roof when lifted? The car is 2006 coupe. On occasion when lifted the hatch will just barely touch the roof enough to scrub the paint in the center about one inch wide. Still under warranty, but would appreciate any advice before the dealer gets into the problem and potentially makes it worse! Thanks.
Old Dec 2, 2007 | 01:18 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
Not me, did you have the roof replaced at all?
Old Dec 2, 2007 | 01:21 PM
gbgary's Avatar
gbgary
geesh, you made me go look. mine's not even close. the higher it goes the further from the roof it gets. you have a problem for sure!!!
Old Dec 2, 2007 | 01:40 PM
VET4LES's Avatar
VET4LES
No problem here.
Old Dec 2, 2007 | 02:26 PM
V8 Juice's Avatar
V8 Juice
No, stock roof, no changes. It is the fixed portion at the rear of the top, not the removable roof panel, that is the contact area. The car has about 25 HPDE track days, but I don't see how that would affect the hatch alignment.
Old Dec 2, 2007 | 04:53 PM
calemasters's Avatar
calemasters
Have the hatch adjusted.
Old Dec 2, 2007 | 05:05 PM
Ozone's Avatar
Ozone
Sounds like you hatch adjustment is just a little out of whack. I'd take it to the dealer to have it looked at.
Good Luck.
Old Dec 2, 2007 | 07:29 PM
V8 Juice's Avatar
V8 Juice
Good Luck.
Thanx guys; going to dealer Tuesday; will post result when "fixed" ??!!
Old Dec 2, 2007 | 07:58 PM
GaussianMist's Avatar
GaussianMist
Do you have the word "salvage" on your title? J/K. Go get er fix!
Old Dec 2, 2007 | 09:28 PM
User 020720's Avatar
User 020720
Looks like you need a Z06, it has a "fixed" roof.
Old Dec 3, 2007 | 12:10 PM
V8 Juice's Avatar
V8 Juice
Or perhaps the new ZR-1!! Any of you going to the "Detroit Reveal" sponsored by NCM to see the new car?
Old Dec 3, 2007 | 04:36 PM
C6 Fan's Avatar
C6 Fan
I'd also check the roof (bow), it's held on by screws to the frame. See if it's sticking up (visually where it's hitting. May be a loose screw
Old Dec 4, 2007 | 06:34 PM
V8 Juice's Avatar
V8 Juice
Dealer says the weather stripping needs replacement, slight alignment and paint touch-up at point of contact. The problem is rare, but not unprecedented. Watch your clearance when you open the hatch, especially if you are still in warranty!
Thanks for recommendation to fix the roof by getting a fixed roof (Z06) and that I have a screw loose, or was it loose screw?
Old Dec 4, 2007 | 06:55 PM
fleetc's Avatar
fleetc
I looked at mine last night. It does come mighty close. About 1/2inch. I'll keep an eye on it.
To Hatch hits roof
