visors
Old Dec 2, 2007 | 04:48 PM
FEAR's Avatar
FEAR
Default visors
Does anyone know how to remove the sun visors? i want to remove the drivers one, i am tall and it will give me much better visibility without it.
Old Dec 2, 2007 | 05:06 PM
stanleyp's Avatar
stanleyp
3 screws where it is attached to the roof.
You'll be left with an ugly hole.
Old Dec 2, 2007 | 05:08 PM
FEAR's Avatar
FEAR
no screws in mine
Old Dec 2, 2007 | 05:20 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The visor is not held in by screws. If you look at the base of the visor you will see the track where it rotates side to side. In the center there is a slot perpindicular to the arc of rotation. You will need to fold the visor down and place a flat blade screwdriver in to that slot.
Now rotate the visor towards the side window while holding the screwdriver in the slot. You want the arm of the visor to press against the screwdriver as you rotate. At about 45 degrees towards the window you will be able to pull the assembly down out of the roof.
Old Dec 2, 2007 | 05:26 PM
Modshack's Avatar
Modshack
Instructions here: http://temp.corvetteforum.net/c5/kvozel//slide1.jpg
Old Dec 2, 2007 | 05:52 PM
stanleyp's Avatar
stanleyp
Originally Posted by FEAR
no screws in mine
OH, MAN!!! WTF was I thinking?
I was thinking of the.... oh, never mind. :o
Old Dec 2, 2007 | 05:54 PM
FEAR's Avatar
FEAR
What did you use to finish off the hole? looks good!
Old Dec 2, 2007 | 06:18 PM
FEAR's Avatar
FEAR
done! thanks for the help!
Old Dec 3, 2007 | 06:18 PM
08C6Vert's Avatar
08C6Vert
Default Visors
The huge visor arm really bothers me from both a safety, looks and weight perspective. Does anyone know of a replacement that has a much smaller arm supporting the visor?
Why does the visor need such a huge support arm? Seems like GM missed an opportunity to save some money here.
Anyone else agree?
Old Dec 3, 2007 | 07:37 PM
timd38's Avatar
timd38
If you have the garage door opener option, it is in the visor...
To visors
