New Keyfob Programming Problem.... And Learned Settings
Old Dec 6, 2007 | 11:29 PM
Bryanwithy's Avatar
Bryanwithy
Default New Keyfob Programming Problem.... And Learned Settings
I need some help, in a nutshell how do you delete the known keyfobs from the car?
I recently purchased a new style fob from a forum member...Thanks Gary .....And followed the programming procedures. The issue was I read the directions and thought that i could "choose" which number fob it would be, now as I know I cant do that.
Anyways help would be appreciated on how to delete the known fobs to start fresh.
Also can you delete the learned information the car stores such as transmission driving habits, etc?
Old Dec 6, 2007 | 11:47 PM
Vette_DD's Avatar
Vette_DD
Use the second procedure listed here.
http://forums.corvetteforum.com/show...2&postcount=14
I don't know if there's a way to do this or not. I doubt it.
Old Dec 6, 2007 | 11:53 PM
Bryanwithy's Avatar
Bryanwithy
The problem is I have no "Unrecognized" fobs, they have all been learned. I tried that procedure today.??????
Old Dec 7, 2007 | 12:37 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Your only option may be taking it in to Mr. Goodwrench and having him do the "programming".
However, the instructions in the following post may work if you follow them exactly. Of course, in your case, you will not be placing an "unrecognized fob" in the transmitter pocket. Give it a try - it may save you a trip to the General.
http://forums.corvetteforum.com/show...25&postcount=5
Good luck!!
Old Dec 7, 2007 | 10:42 PM
Bryanwithy's Avatar
Bryanwithy
Good luck!!
Tried that today, still no luck. I hope someone has answer before i head to the general.
To New Keyfob Programming Problem.... And Learned Settings
