Nav questions...
One thing that I find to be an annoyance is the fact that you can only control the stereo from the Nav screen itself, and that you can only see the radio information on the Nav screen. I understand you can get radio information on the HUD as well.
- Does the radio information show up on all HUD modes?
- What exactly is displayed on the HUD for the radio information?
- Is the only way to turn on the radio by turning on the Nav first?
- If you have the radio on playing station XYX, or CD on track 5 and you turn off the car w/o turning off the radio/nav, then turn the car back on, does the radio automatically come back on playing the same station/CD or do you have to manually turn the radio/nav back on?
- I assume there is no other voice command button on the steering wheel anywhere, only on the nav unit? (This seems crazy to me coming from the TL with the voice button on the wheel right at your fingertips. Of course, whoever designed the steering wheel controls and put them on the right side of the wheel must not drive much, especially not manual cars).
- When you have the map displayed on the Nav unit, does it show the name of the street you are on?
- When using the Nav and you are coming up on a turn, does it tell you just to "turn left" or does it show the name of the street to turn?
- This may be a stretch but does anyone have any pictures of the nav screen in map and radio mode?
Sorry for all the questions but I have been thinking about changing my order to a non-nav unit. However with the non-nav unit, I really don't need 6 CDs but I do like the MP3 jack. Except that the person who designed this jack must be the same one who put the stereo controls on the right side of the wheel. I mean what idiot would put the jack on the top of the center stack??? Most ALL other cars with MP3 jacks have them inside the center consoles where they belong along with a 12VDC jack for power. Some common sense would be nice.
Thanks.
Lou S.
- Does the radio information show up on all HUD modes? No, only in street mode.
- What exactly is displayed on the HUD for the radio information? Not much...like the tuned frequency...and only for a short while when you change the station.
- Is the only way to turn on the radio by turning on the Nav first? No, the radio controls are separate. You can have the radio/CD on without ever engaging the NAV.
- If you have the radio on playing station XYX, or CD on track 5 and you turn off the car w/o turning off the radio/nav, then turn the car back on, does the radio automatically come back on playing the same station/CD or do you have to manually turn the radio/nav back on? If you shut the car down with the radio on or a CD playing, when you restart the car the radio comes back on to the station that it was on or if a CD will begin playing the track you were listening to when you turned the car off.
- I assume there is no other voice command button on the steering wheel anywhere, only on the nav unit? (This seems crazy to me coming from the TL with the voice button on the wheel right at your fingertips. Of course, whoever designed the steering wheel controls and put them on the right side of the wheel must not drive much, especially not manual cars). The voice command button doesn't really matter because the voice command is semi-worthless. It just doesn't get it right very often.
- When you have the map displayed on the Nav unit, does it show the name of the street you are on? Yes, along the bottom of the map.
- When using the Nav and you are coming up on a turn, does it tell you just to "turn left" or does it show the name of the street to turn? I don't think so. I think it just tells you to turn in XXX feet. I don't remember for sure.
Sorry for all the questions but I have been thinking about changing my order to a non-nav unit. However with the non-nav unit, I really don't need 6 CDs but I do like the MP3 jack. Except that the person who designed this jack must be the same one who put the stereo controls on the right side of the wheel. I mean what idiot would put the jack on the top of the center stack??? Most ALL other cars with MP3 jacks have them inside the center consoles where they belong along with a 12VDC jack for power. Some common sense would be nice. Can't help you with this one since I have an '06 and don't have any MP3 jacks.
Thanks.
Lou S.
Good luck with your decision.
Thanks.
Lou S.
To help you make up your mind about getting the nav, it would probably be a good idea to look at the NAV Manual (see below) and read about all the features that the unit offers. Hopefully, it will help you make a more informed decision.
2008 Corvette Navigation System Manual
When you are using the nav and listening to xm, cd or radio, you push the "source" & "NAV" button to toggle back and forth between the nav map and these features. When you get close to a turn, the music volume decreases and the woman's voice comes on to inform you what your next move is.
The HUD shows station/track changes for the radio/xm and CD. It shows the name of the street, how far away it is and which way to turn when the nav is being used.
Overall it is pretty cool.
Wait to see for yourself what the screen looks like yourself before you form an opinion on it. I think it shows you everything you need in a useful format.
Don't worry about the lack of steering wheel voice button. At least for me, when I have my hand on the shift, the Nav buttons are only a fingertip away.
I have a Pioneer Z2 in my F150. It's a great system but it too has it's faults.
If I got to order my vette, I would've gone no Nav and put an aftermarket in.
1.
2.
Many if not most of the problems that people report about bad directions and erroneous recalculations are simply user error. With that said, the OEM unit is not as easy to use as most portables nor as intuitive as most other OEM units. It can be learned and used very effectively for what it was intended to do. You need to invest the time to learn to use it properly so that you are not surprised by things it does. If you tell it you want to take the fastest route it may go out of its way to take the highway...including taking you out of your way to get on the highway.
I much prefer the touchscreen interface to that of a conventional radio. I much prefer the HUD integration to any alternative GPS.
Have a look at the manual from the link provided above and judge for yourself. I think you will find that it is quite beneficial.
The voice commands work at least 95% of the time for me and when it doesn't a second try almost always works. Yes, it would be nice if the button was on the steering wheel but the top left of the nav is almost as good since you can easily find it without looking. You just have to speak clearly and say words it understands rather than trying to make up a new language that makes sense to you. For example, "Get rid of the icons" doesn't work but "POI off" does.
Yes, there is a street name on the HUD for turns as well as a bar graph countdown of distance to the turn and the direction to turn. It even knows the difference between turn right and bear right.
It DOES recalculate the route if you miss a turn (or just want to go another way). Yes, it might tell you to make a U-turn if that is the best way but since I keep mine set for quickest it almost never does that. Set it for Normal and it will want to put you on Interstates whenever possible. Shortest will run you down alleys if it is shorter. It is only doing what you asked it to do. And it is constantly calculating the route you asked for to the destination you specified. (Some people don't understand how to set destinations and waypoints and the difference between them.)
Finally you CAN set destinations while moving. It is just a limited set. You have 6 preset destinations and you can pick any of those while moving. You can also select from emergency destinations (closest hospital, police, etc.) while moving. You can NOT decide while you're moving that you want to enter a phone number of a business and go there. You have to pull off the road (it seems to be about 5mph where it comes on) to start a destination from scratch.
Finally there are several map displays. Full screen maps, splits screen with map and turn list, split with full map and detail map, split with map and BIG turn arrow, 3D, etc. None of this is really covered in the manual. You just have to push buttons and see what happens. The one thing GM could do to improve the nav tremendously is rewrite the manual and include all the features (and remove the errors).
Leon Resnick
Not the best, but better than nothing.
As for the nav itself, a couple of things to remember. First, it is a generation behind the newest stuff. This nav was designed in 2002-2003 to be put into the 2005 C6 in mid-2004, so it doesn't work as well as the newest stuff. That said, it still works quite well.
The voice prompt will tell you major road names, streets, etc. Mine does it all the time ("Turn left onto 4th St.," "Bear right onto I-35 South," etc.). I don't know what others' are doing, but mine says it all the time.
The voice recognition, I have to agree, is next to worthless UNLESS you are sitting still with the engine off. Why? The microphone is in the A-Pillar, driver's side. Any wind noise on the glass, etc. cancels out your voice. Same problem with OnStar and the phone - the wind/road/engine noise cancels out the microphone a lot of the time. Don't bother.
So if you can have the radio on w/o engaging the Nav, where does the radio information get displayed? On the Nav screen?
Reason I am asking is in my TL, when the car is first turned on, the Nav system boots up and actually takes about 25 seconds to get to the "agree" screen (so the 7-10 seconds I've heard about the C6 nav is not that bad really). However, I can hit the "audio" button and have the radio information displayed on the nav screen immediately, even if the Nav is still booting up. Difference with the TL, there is a separate LED screen that displays the radio info and clock so if you want, you don't have to use the Nav screen at all (as if it is washed out in the sunlight when the sun roof is open).
Thanks for all the responses too.
Lou S.
Lou S.
From what I can garner from the forum and NAV owners I have met, I made the right decision. Yeah, the Pioneer isn't perfect, but, it is much closer in operation to the other factory systems we have had.
BTW, if you look at the trade in value of the factory NAV, it is nothing to write home about. At least you can remove the aftermarket unit.
I just bought this NAV and just sold it. I guess I am spoiled. I have a Nissan Titan for my daily driver and it has the NAV. I now know that it is a really really good NAV. Just didn't have anything to compare it to until I bought this GM NAV.
The biggest thing that was a deal breaker for me is that it doesn't have the ability to show your route in a different color even if the roads you will be on are the "incomplete map data" roads, a.k.a. side streets that are not main routes.
For example, If I go from A to B with the Nissan NAV and there are roads that are side streets not considered to be main roads that the NAV has full information on, the Nissan NAV will say "Entering the road with incomplete map data" but still hightlight these roads so you know exactly which one(s) you should be on. It may take 4 or 5+ side roads to get to your destination but the NAV will have them highlighted in green so you know which ones to take.
The GM NAV says something near the same about incomplete map data but doesn't highlight the side roads that you are going to need to take. If it is several miles of side roads with several turns, you're nearly screwed. To make the matter worse, the side roads are very faint on the screen regardless of the screen settings.
Just not very impressive. I remember saying to myself how I can't believe that I just went through all this BS to add this NAV and this is what my prize was.
I have the NUVI 650 on its way. Was a great price too and I feel a hell of a lot better about using it.
Oh ya, one other thing, the head unit for just playing music is better in the 6-disk head unit vs the NAV head unit. I am starting to think that a lot of the complaints of the factory stereo come from people who have the NAV head unit. The NAV head unit regarding playing music was just ok. The 6-disk head unit jams rather well and noticeably better.
