Finally!
Old Dec 18, 2007 | 02:47 AM
Invisiguard's Avatar
Invisiguard
Default Finally!
just ordered 3, think thats enough??
http://www.streetperformance.com/par...r-bearing.html
Old Dec 18, 2007 | 04:48 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
That must be for the NPP exhaust system.
Old Dec 18, 2007 | 06:07 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Actually, it is made for ANY MUFFLER that drones!
Old Dec 18, 2007 | 06:49 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
wtf (what-the-funk)
muffler bearing??? never heard of such a thing. please enlighten me.
just got it.... i need to get me a set of 'dem 'cross-drilled' brake lines'
don't tell my wife about this product though.... that's all i'd need never have an excuse again.
http://kalecoauto.com/index.php?main...products_id=20
Old Dec 18, 2007 | 07:33 AM
Dogue's Avatar
Dogue
With all the bad muffler bearings out there I can't believe it took this long for someone to make a replacement . I'm buying stock in Kaleco ASAP!!!
Old Dec 18, 2007 | 07:34 AM
rws.1's Avatar
rws.1
These oldies keep coming up from time to time....
I usually find myself re-amused.....
Old Dec 18, 2007 | 07:38 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
You da man.
Old Dec 18, 2007 | 07:53 AM
don kopfman's Avatar
don kopfman
Originally Posted by ben dover
You da man.
i would buy a set but no 08 year vette listed i will just run my old ones till they melt down or my npp gets too loud.
Old Dec 18, 2007 | 07:56 AM
VET4LES's Avatar
VET4LES
This is just what I've been looking for.
Old Dec 18, 2007 | 07:58 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
forum member Kale's stuff...
Old Dec 18, 2007 | 07:59 AM
avacorvette's Avatar
avacorvette
From: Canonsburg home of Yenko Chevy (gone but not forgotten) Western PA
I had a big problem with the Kaneuter Valve that I ordered from the same company.
Old Dec 18, 2007 | 08:22 AM
GaussianMist's Avatar
GaussianMist
OK, how many HP will you gain? The bigger ball bearings always push the car to its limit, a little scary to drive.
Old Dec 18, 2007 | 08:49 AM
Mark-44's Avatar
Mark-44
Default "One per muffler"
I think you ordered one too many; the ad says, "one per muffler."
Old Dec 18, 2007 | 10:32 AM
C6NRED's Avatar
C6NRED
Well, without a doubt, he should order a spare, as the Corvette is well known to abuse its muffler bearings. Always good to have a spare on hand when one goes out.......I am surprised that there have been no Flux Capacitor comments yet.....oops, there it is.........
The poor build quality of the '08, as documented so well here is obviously responsible for the quality of these bearings. Perhaps every owner of an '08 would qualify under the lemon law in this case.
Old Dec 18, 2007 | 10:54 AM
traindude's Avatar
traindude
Most likely any HP gain be offset by the weight of these.
Old Dec 18, 2007 | 12:58 PM
OnyxC6's Avatar
OnyxC6
I had to use a metric hammer to get them to fit properly.
Old Dec 18, 2007 | 01:19 PM
mpuzach's Avatar
mpuzach
Does it come with iffin pins (2 required per muffler) or do they need to be ordered separately?
To Finally!
Old Dec 18, 2007 | 01:31 PM
mcwire's Avatar
mcwire
Old Dec 18, 2007 | 01:52 PM
User 020720's Avatar
User 020720
My favorite are the cross drilled brake lines, you must replace them all at once but you can mix & match colors.
It helps if you install them with a left handed metric screwdriver though.
Old Dec 18, 2007 | 01:56 PM
User 020720
You'll get more horsepower if you install the O pipe, yes an O pipe, not an X or H pipe.
