Do it yourself NPP Wireless Switch...
Old Dec 18, 2007 | 03:16 PM
c62008vette's Avatar
c62008vette
5th Gear
Default Do it yourself NPP Wireless Switch...
I recently got a 2008 Corvette with the NPP Exhaust.
I did some research on readily available wireless controls and came up with my own solution that is much cheaper while still retaining the coolness of a wireless control.
First you need to buy the wireless receiver with key fobs. The one that I used I got from Newegg.com - it's called the Logisys Computer RM01 12V Remote Control Molex Connector Kit. It retails for like $12.99.
Depending on the maximum AMP rating on the RM01, you can also find a RM02 that is usually only a few bucks more that's rated to 15 AMPS of something like that. Newegg doesn't sell them, but I've seen them all over the place
RM02 Sources (OR THERE ARE LIKE A MILLION OF THEM LISTED ON THAT HUGE AUCTION SITE - search for Logisys RM02)
Item # 46044 - Mini Fuse Circuit Tap $8.05
Item # 37065 - Mini Tapper Fuse Clip Push On $0.10
I also used a ring terminal that I had laying around for the ground wire connections.
Basically I ran the red wire from the wireless receiver to the red wire end of the mini fuse circuit tap. I put a 10A fuse on the one end of the circuit tap and used the mini tapper fuse clip connected to the white wire coming out of the wireless receiver right next to the 10A fuse on the left side of the fuse connection. The 2 black wires coming out of the wireless receiver were connected together with the ring connector and screwed into a grounded screw spot under the dash.
The mini fuse end of the circuit tap was inserted into the fuse slot that everyone talks about removing to disable the NPP system.
Bingo, now you can turn the exhaust on and off wirelessly!
Last edited by savewave; Dec 20, 2007 at 06:14 PM. Reason: No links to non-supporting vendors
Old Dec 18, 2007 | 03:26 PM
FLY US's Avatar
FLY US
smart...you just saved
alot of people
alot of money
Old Dec 18, 2007 | 03:29 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
alot of people
alot of money
Good job.
Old Dec 18, 2007 | 03:32 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
alot of people
alot of money
Very nice!!
Old Dec 18, 2007 | 03:38 PM
DC321's Avatar
DC321
I know a guy who charges $1.00 for information like this....
Old Dec 18, 2007 | 03:47 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Old Dec 18, 2007 | 04:21 PM
kdhand's Avatar
kdhand
I have mixed emotions on this - I will look to save $ where possible, but like to see vendors support us and our cars - maybe we can have the best of both worlds with postings like these helping to keep down the Corvette tax!
Old Dec 18, 2007 | 04:24 PM
c62008vette
5th Gear
I agree. I'm not trying to take $ away from anyone. There is also the risk of screwing something up if you don't know what you are doing. The commercially available options are good for those that don't like to tinker. I do like to tinker and to be honest, there isn't much rocket science behind this solution.
If someone else can save a few bucks and has the desire to do it themselves?? They should at least have the option right?
Old Dec 18, 2007 | 04:40 PM
Dogue's Avatar
Dogue
Old Dec 18, 2007 | 05:16 PM
JerriVette's Avatar
JerriVette
I appreciate the information. I still prefer to pay one of our vendors for a complete kit.
The difference in cost is not much and I know I have the technical support should something be needed.
Thanks for the heads up. I probably should save the few dollars and do it the way you suggest but I'll probably just buy a kit from one of the vendors here..
I can't figure out why one vendor sells his at 45 dollars and another sells his for 90 though..
Anybody know what the difference in kits is (besides the price)
Thanks in advance.
Old Dec 18, 2007 | 05:28 PM
anotherone's Avatar
anotherone
this is exactly what I did and it is the same as the high priced unit. Matter of fact look at the pictures ; their identical. My total cost about $20. Dont let the scaredicats bluff you away with that battery drain bs.
One down side about driving in the open mode ; it makes you want to push the gas pedal down more to hear that pure cool sound.
Old Dec 18, 2007 | 05:56 PM
kdhand's Avatar
kdhand
That would be the "user tax" more fun = more gas
Old Dec 18, 2007 | 06:08 PM
rjr2007's Avatar
rjr2007
Old Dec 18, 2007 | 06:39 PM
Corellian Vette's Avatar
Corellian Vette
For the DIY this is great. For ones that cant or dont want to can buy the premade ones.
Old Dec 18, 2007 | 07:15 PM
AO-08's Avatar
AO-08
Default ready made 4 me
Hey Ed don't worry too much.
Most that are going to actually spend hours finding, ordering, then assembling the parts to make the knock off W2M switch would more than likely be to cheap to buy from you anyways.
I've had way more than $90 worth of pleasure from my W2M switch I'll tell you that!
Agreed the idea is what matters, copies are much easier.
Thank you Ed
Old Dec 18, 2007 | 07:25 PM
c62008vette
5th Gear
Originally Posted by Pipedreams
This is great for the DIY guys
Wow, you are a brand new member (no profile) and this is your first post, can't wait to see what is next. Actually it much more like all the other attempts to attack the product I developed over 16 months ago and sell commericaly on this very forum. Most likley buy a few of the members that harass me on a regualar basis.
I have given up trying to defend my original creation, which when I developed it 16 months ago required me to have a custom control built . Eventually I will stop posting new and unique products since they only have lead to both my business and original creation attacked.
In the past DIY’s of vendors existing creations were protected, that has changed I guess due to pressure from a few. I am sure you will see them chiming in on this post.
Vendors pay a good fee to have the opportunity to sell on this forum. The links to the ones above were not vendors last time I checked.
It's always simple to look at a product and copy it. I look at what has not been developed and make it as was the case with the first wireless exhaust switch. That no one can take away from me
Enjoy the DIY
Not trying to attack anything... Just pointing out an alternative. Is that wrong? I can't help that the parts are readily and easily available at a multitude of places.
Old Dec 18, 2007 | 07:34 PM
hulksdaddy's Avatar
hulksdaddy
My take is this: I could buy the parts from a couple of different places, possibly get them at different times, spend my time putting it together, then if it doesn't work, try to figure it out and if I can't, return both for replacement.
Or I can buy mine from Pipedreams and pay a little more, sure, but I get it in a couple of days, hook it up in 2 minutes, and if I have any problems, Ed ships me a new one.
I gladly paid for that service.
To Do it yourself NPP Wireless Switch...
Old Dec 18, 2007 | 07:37 PM
Gibson_L5's Avatar
Gibson_L5
A simple relay...nothing inovative about it.
I prefer a footswitch... who needs another remote to fumble with....
keep it simple...my opinion.
Old Dec 18, 2007 | 07:45 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
I especially liked the post "you just saved alot of people alot of money" Yea, about the cost of a tank of gas and a few hours of extra time. Thanks for this "valuable" info.
Old Dec 19, 2007 | 02:24 PM
calvie018's Avatar
calvie018
glad to see this thread is back
