Battery Tender/ lightning question
Old Dec 22, 2007 | 02:44 PM
Pylons26's Avatar
Pylons26
Default Battery Tender/ lightning question
My house got hit by lightning about 5 years ago so I am a
little skittish about it. I know it's winter in Pa. and the chance of
a lightning strike is slim to none but if I have my car
hooked up to a tender and house gets hit, will it fry the electronics
in the car? What about a power surge (for whatever reason).
If you were going on vacation and your car was on a tender would
you unhook it?
I'm not to concerned about it, I just "pondering" it.
Old Dec 22, 2007 | 02:53 PM
dvilin's Avatar
dvilin
I do not think I would be concerned with lightening striking again. As for vacation I head South for 10 weeks and leave the Battery Tender connected with no worries.
Old Dec 22, 2007 | 03:09 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I leave mine on. We take off for 2 weeks at a time, not loosing sleep over a problem.
FWIW my instruction sheet says if powere is off to unit it will SLOWELY draw some power back from the battery. We had a power out last year lasted about 20 hrs. When power went back on, within 20 minuets it had went back to green LED showing. That tells me the power draw while off is no big deal.
Old Dec 22, 2007 | 03:19 PM
calemasters's Avatar
calemasters
It the device does not have voltage spike protection built in, just plug it into a surge protector.
Old Dec 22, 2007 | 03:21 PM
Gibson_L5's Avatar
Gibson_L5
Over the years I have sent many back due to voltage spikes or worse low voltage, I switched to CTEK but have them all on a voltage conditioner - surge protector now. A cheap surge protector is cheap insurance. The tech for Battery Tender suggested it.
Old Dec 22, 2007 | 03:54 PM
carpe dm's Avatar
carpe dm
Old Dec 22, 2007 | 04:06 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Oh, great! Now I have to get a super whammy surge protector, to protect my battery tender, which protects my car battery. Geez, it keeps getting more interesting-er and more interesting-er.
Pretty soon I'll need a dedicated generating plant solely for keeping my electricity running to my car via my surge protector and my battery tender. Of course, with nucular power (misspelled intentionally).
Old Dec 22, 2007 | 04:22 PM
rakuhn's Avatar
rakuhn
I never gave it a thought before. The socket mine is plugged in to has one of those red buttons that does something.
We don't get too much lightning up here during the winter. We tend to be gone for extended periods of time during the winter and I have never unplugged it.
Old Dec 22, 2007 | 04:42 PM
mcwire's Avatar
mcwire
Why can't GM solve the problem, and eliminate the need for a "battery tender" ?????
Old Dec 22, 2007 | 05:31 PM
holdin5aces's Avatar
holdin5aces
Default baby ;chicks
cheep cheep cheep
Old Dec 22, 2007 | 05:41 PM
LeedDog's Avatar
LeedDog
Default Lightning didn't hurt my C5
A few years ago I had a Battery Tender attached to my C5 and a lightning strike fried my Battery Tender but didn't affect the C5. I returned the Battery Tender to their factory and they replaced it at no charge.
Old Dec 22, 2007 | 06:03 PM
johnodrake's Avatar
johnodrake
Moderator
Solve what problem?
Old Dec 22, 2007 | 06:04 PM
ProfMoriarty's Avatar
ProfMoriarty
Even though both of mine are connected to surge protectors, I still unplug them when thunderstorms are predicted.
Old Dec 22, 2007 | 06:06 PM
mcwire's Avatar
mcwire
Originally Posted by johnodrake
Solve what problem?
The "dead battery syndrone". I would assume (I know what that does) that the use of a battery tender, is to avoid a dead battery.
Old Dec 22, 2007 | 06:10 PM
DEO's Avatar
DEO
I have a whole house nanosecond surge protector wired into the main. No worries here.
Old Dec 22, 2007 | 06:14 PM
Gibson_L5's Avatar
Gibson_L5
The reason for a voltage conditioner is that if your power company is poor as is mine, my voltage can go from 108 to 128VAC...which is bad for any IC equipment. A "cheap" surge protector is a thyristor which is like a fuse, once and done. A Tripplite voltage conditioner converts low to high voltage as mine to stable 120, protected. It's not the cost of sending the tenders back.... it 's the pain in the butt to walk in after a month and see both lights on..dead batteries... smell the burnt electrical ....it may be overkill... but I need to do it... Most probably do not.
Old Dec 22, 2007 | 06:18 PM
Gibson_L5's Avatar
Gibson_L5
What company did you use?
To Battery Tender/ lightning question
Old Dec 22, 2007 | 06:33 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Electricity needs a path. When you get a lightning strike close the path is either through the hot wiring coming to the house to ground OR from the ground around the house through the hot wiring to someone elses's house and their ground. In either case there must be a path from the lightning to a distant ground potential. The Battery tender can get in that path and be fried. A surge protector short circuits that path from hot to ground through the surge protector and limits the potential the tender sees. As far as the car goes it is always out of the path because of the rubber tires. Even if you somehow get more than 15 volts between the battery terminals, the battery provides a low impedance path just like a surge protector would. I would not worry at all about the car. I would get a surge protector for the battery tender if I was that concerned. Personally I'm not.
Old Dec 22, 2007 | 07:41 PM
siffert's Avatar
siffert
You are so **** My estate got hit by lightning 5 years ago and I then got surge protectors on everything. By the time it would take me to unplug everything, we would be into the next season
Old Dec 22, 2007 | 09:42 PM
ProfMoriarty
Yours is the typical *** backward example of closing the barn door after the horses have run out.
I have surge protectors on my more valuable electrical equipment.
For the stuff that I most definitely don't want to get fried, I unplug them when there is a report of impending thunderstorms. If I'm going to be out of town for a few days, I unplug them as well.
Last count that was 4 plugs.
If it takes you more than a few minutes you might want to consider hitting the gym and doing some cardio.
