Hatch lid closing problem
Old Jan 1, 2008 | 11:50 PM
NYC6's Avatar
NYC6
Default Hatch lid closing problem
It started the other day. When the car is not running the hatch lid pull down wont pull down all the way. When I start the car it seems to work fine. I had sound system installed a couple of months ago and Im wondering if the two amps are weakening the battery or if any of you guys had this issue. My volt meter is showing a good charge to battery.Any ideas?
Old Jan 1, 2008 | 11:58 PM
bosco 08's Avatar
bosco 08
did the problem start as soon as the sound system was installed?
Old Jan 2, 2008 | 12:18 AM
NYC6's Avatar
NYC6
No. It just started,thats about three months after.
Old Jan 2, 2008 | 12:48 AM
bosco 08's Avatar
bosco 08
then you can probably rule that one out. next thing is what was the voltage reading of the battery at room temp fully charged? should be 12.8 to 12.9 using a digital VOM
State of Charge Specific Gravity Voltage
12v 6v
100% 1.265 12.7 6.3
*75% 1.225 12.4 6.2
50% 1.190 12.2 6.1
25% 1.155 12.0 6.0
Discharged 1.120 11.9 6.0
Old Jan 2, 2008 | 12:53 AM
NYC6's Avatar
NYC6
Electricity isnt my gig, Im assuming these numbers are with engine off?
Old Jan 2, 2008 | 01:16 AM
bosco 08's Avatar
bosco 08
it's all here. load testing is also a good check any shop should do it for free.
http://www.batterystuff.com/tutorial_battery.html
Old Jan 2, 2008 | 01:19 AM
NYC6's Avatar
NYC6
Thanks for the help.
Old Jan 2, 2008 | 01:38 AM
bosco 08's Avatar
bosco 08
another thing to consider is if you have big amps that pull a lot of power and your charging system isn't up to the task then it puts undue stress on the battery ie, alternator is too small for the job at hand. this shortens the life of the battery. the wire sizes also need to be increased for the increased current draw to the amps.
To Hatch lid closing problem
