Gutter Guard Question
Jan 5, 2008 | 09:08 AM
If gutter guard is used for front fender grills, does it need to be painted to prevent rust from forming? Thanks.
Jan 5, 2008 | 09:29 AM
St. Jude Donor '06-'07
Quote:
Originally Posted by
op z
no, the are galvanized steel so they should not rust. I have the template on
www.nakidparts.com under DIY's
Jan 5, 2008 | 09:38 AM
Pipedreams
Thanks for the quick response and the template. We have nice weather in KS today and I'll give this mod a shot.
Jan 5, 2008 | 09:39 AM
op z
anytime, I painted my comp gray to match my wheels
Jan 5, 2008 | 10:05 AM
Pipedreams
Do you have a pic? As you can see, I have comp gray wheels as well and was considering the same. Where did you buy your paint?
Jan 5, 2008 | 02:12 PM
op z
I just use the duplicolor truck spray called T183 (gray metalic) Pboys has it
Jan 5, 2008 | 04:57 PM
Pipedreams
Looks great for the cost!
Jan 5, 2008 | 05:02 PM
jd94534
$3.50, industrial velcro is the trick, mine are on almost 3 yrs and never had to redo them. The velcro works because it gives a little without letting go
