Scary Codes
- They call GM - solution 1 - replace main computer...
24 hour later - same problem - Call GM - Solution 2 - replace Starter....
24 hours later - This works.
You would think this could be simpler
In case any of you run into this, I thought you might want to know...
If the vehicle has any of the crank sensor codes P0335, P0336, P0385, or P0386 set, then the following should be done:
• Inspect both of the crank sensor terminals for signs of poor connection or corrosion of both crank sensors. Pin drag test all four terminals.
• Inspect the crank sensor circuit wires for signs of damage.
• Inspect the crank sensor circuits at the PCM for poor connections. The crank sensor terminals should also be drag tested.
• Remove the crank sensors and check for any debris on the sensor.
• Verify crank sensor location (A on the bottom and B on the top) and verify that the sensor circuit wires are in the correct cavities.
• Inspect the date code on the sensor. If it is before 0276, replace the crank shaft sensor and perform case learn.
• If the date code is past 0276, verify the PCM grounds. A voltage drop test should be less than 20 mV.
• If the PCM ground circuit verification is acceptable, then follow published PCM diagnostics.
I am glad I bought the extended warranty... this was at 56k miles (daily ride)
Me too!
