"Has the tape held up since you first installed them?"
No problems with the tape. Solid as when I installed them.
Which models did you get short or long? (in the image)
It is hard to tell from the image, do you have them on the front as well?
Are those OEM size wheels or larger (if so what size)?
Have you done any track time with them on? If so did they help protect the 1/4 panels from marbles effectively?
"Which models did you get short or long? (in the image)" Stock ZO6 Modified
It is hard to tell from the image, do you have them on the front as well? Small guards from PipeDreams on front
Are those OEM size wheels or larger (if so what size)? Stock wheels, BFG KDW II's one size over stock front and rear
Have you done any track time with them on? If so did they help protect the 1/4 panels from marbles effectively? No track time with them but they've been on for almost a year and around 12,000 miles and they offer complete. protection
