Trunk Partition!!!
I just got mine and I have a question for those that have used it for some time:
Does the hard plastic part cause any damage where it is in contact with the plastic vette part??? (Top photo of post 14)
BJK
BJK
Cruise-In VIII Veteran
Why are you talking about the cargo organizer? This was not the question! Even title of post is "Trunk Partition", not organizer. The Exotic Vettes partition will allow the top to be stowed with the partition in place.
Now the cargo organizer Will Not fit with the partition in place.
Trying to use both a partition and the organizer doesn't make sense to me anyway.
These two parts are not in contact with each other. It just looks like it from the angle of the picture. If they do happen to touch, would not think there would be any damage.
Yes, that is a Lloyd's mat and the Exotic Vette partition fits fine with it. There is extra carpet material attached to the front of the partition. Tuck that under the front of the cargo mat and then push the extra material on the sides up and under the rear speaker grills. Don't cut anything and take your time. Extra material will disappear when all done.
BJK
Got my partition today. It took a few minutes to get it unpacked (or unbundled) as it was very well wrapped.
I was surprised there were no instructions. But then there really is nothing to the installation. Swiftrider08 and alanancy pretty much said everything you need to do to install it.
Now I'll have somewhere better than the passenger floor to put my thermos when I drive to work tomorrow.
i've got the exoticvettes partition. i'm not completely happy with the way the roof fits in there with it but it does fit. it seems to rub the front of the roof. as much i have the roof off i hope it doesn't bother the paint over time.
I'm not exactly sure what the problem is with removing the partition is when storing the roof. I have the Southern Car Parts organizer and partition. All I do is simply lay the partition down in the cargo area when taking off the top. The partition is only 3/4 of an inch thick and it doesn't take up much room.
At least that is how it is advertised. I won't be able to test mine until the spring.
exoticvette partition
